1 - 15 of 15 Posts
If I take off the sway bars on my 97 f250... will it make me have less traction? Also will it let me have more flex? What other advantages or disadvantages will I have?:confused:
take em off, it will give you better flex. The only thing that will happen is youll get a bit of body, roll and that is fun stuff let me tell you first hand!
if its your DD get disconects if it worries you too much. But ill tell you they dont make a whole lot of diference unless your pulling a load.
If you don't tow take them off, but on Ford Broncos when you take them off, you get about 2 inches in the front.
If you tow, you should get some JKS swaybar disconnects.
The body roll is a lot less if you have aftermarket shocks , like ranchos or procraps... You can ditch the sway bars, it will help off road. Is this one of those bastard f250's, in the 150 body style? If it's a real F250, then your good..
I own a 4x4 F250 Powerstroke crewcab and was also considering removing the swaybar. I also was thinking of maybe just fabbing up some disconnects. I need to do one or the other, because as it is I bent the end links, when it got hung up on a concrete divider between two parking lots (was only 6 inches on one side... but oops, about 2 feet on the other :D ). Anyway the endlink is bent now and rubs the front leaf springs when I am cornering. My only concern is that this is one HEAVY truck, and it is mostly my DD but it does see some off camber and rough trails on occasion, I also use it to pull my trail rig. I was wanting to know what effect it would have on a pulling a heavy trailer if the front swaybar is removed?
If it were mine and I towed I would completely remove the rear and either set the front up with quick disconnects or run some decent stiff aftermarket shocks. I stuck a solid axle under an explorer with soft springs and I run dual shocks and it sways a bit but it rides nice and makes getting on the trail much faster. But as stiff as your ride probably is from the factory I would think you would be fine without it. Try it just disconnect it and see how it feels to you.
I have a 89 Bronco running 38's both swaybars are gone i tow a 26 ft trailer at times used to be a little hairy but since i started to use a distibution hitch not to bad. if you want good articulation get rid of the bars.
1 - 15 of 15 Posts
