1 - 9 of 9 Posts
hey guys with arb in their toy....liike to get an idea or how and where to mount the switch for my arb and compressor in/on my 84 toy dash! any ideas and pics would be great thanks
nice roach.
Mount it to the right of the steering column just below the gauges where the flat slightly recessed square is, or to the left of the column where the clutch start cancel button would be, since if you have an 84 you more than likely dont have this button.
l8r
-j-rOd
steveh said:
Installed mine on the right:
this looks like what id like to do with mine...did you cut holes in the dash to mount the switches? obviously! what did you use to cut the holes? looks good! some more info plz?!
I took the dash apart, then drew the layout on the dash part, and carefully cut it. I drilled holes in the corners and used an Xacto Jewelers saw to cut it out, and did some minor trimming with a regular xacto knife. It's easy, just take your time. There's just enough room behind it for the ARB harness.
1 - 9 of 9 Posts
