1 - 9 of 9 Posts
switching 351w to electonic distributor* update new question
Newbie from the jeep side with a question for the Ford experts. I want to switch my '78 model 351W to an electronic distributor. I have the distributor, wiring harness, and ignition module. My question is, can I use my old cap and rotor? Thanks.
The old cap/rotor work fine. I have had this setup on my 302 then 351, and a 460. But I did this since I had 9mm taylor wires that fit the older style cap, also I have a bunch of brand new cap/rotors that my dad had laying around for years from when he work in a garage.
Just buy the new stuff.
Ok I have another problem.
It seems the shaft on the Electronic distributor is slightly smaller than the old one, so it doesn't want to slide down onto the oil pump shaft. Can I swap the shafts on the distributors or am I screwed? Both of them are part # 12127. Thanks.
Sounds like you have a 302 distributor. They have a smaller oil pump shaft.
1 - 9 of 9 Posts
