1 - 8 of 8 Posts
Has anyone here cut down the output shaft on a NP208? I had someone tell me the shaft was hollow (or at least through drilled), but i don't see this being possible. I'm looking to slice about 2" off of one, so any details would be nice.
Justin
they are solid. can you get access to a fixed shaft...should save some cuttin unlessit would be too short.
where did you find a 28 spline fixed yoke output shaft? That would have worked even better for what I was doing, The ones that I have around are 32 spline output shafts.
i thought i replied that all mine were 32? :confused: :confused:
musta not went thru...or i pressed the wrong key or somethin.. :confused:
1 - 8 of 8 Posts
