1 - 4 of 4 Posts
what are the differences
in the EFI and carb models
will they work on either tranny
the reason I ask is I have a 1980 Toy
with a 4 speed and I picked up a 5 speed
from a 1985 and was wondering if it will work
Thanks
Richard
[ 10-24-2001: Message edited by: Richard ]
all I know is that the newer ones are a little longer, I would guess that they would be interchangeble since the block stays the same i think, through most of the years. Im not sure about 80 though because the 20R had less displacement so that means different casting, and i dont know if the holes are in the same place. Sorry i couldnt be more help
The only substantial difference in transfercases is where the shifter is located. Some have the shifter in the top of the Tcase, some have the shifter in the tailhousing of the tranny.
Either way, you can change shift rails and shifter seat, and convert one to the other.
If the '85 one came from an EFI truck, you should be good to bolt up and go.
1 - 4 of 4 Posts
