1 - 8 of 8 Posts
Not real knowledgable on t-cases. This is what I have: turbo 350 with Advanced adapter to a stock 87 4cyl (21 spline) t-case. I want to run duel t-case. Will my t-case hold up? I have a dana 60 up front and 14 bolt rear and will be running 44" tires. What t-case setup should I run? My tranny is brand new and the tail shaft was cut to work with the adapter and current t-case. If I run a different dual case setup will my tranny still work?
I need some advice on what to do.
What size engine are you running (if any--didn't see it on the specs you listed)? Toyota t-cases are strong, but they do have a torque limit.
Re: Re: Re: t-case advice please
das_jeepinator said:
my mistake and I'll admit it got a little bit ahead of my self.
the way I looked at it it still has the 4cyl in it with original tcase.
the th-350 gives it away too,probably not the 4cyl anymore.
1 - 8 of 8 Posts
