1 - 20 of 27 Posts
Not sure, but maybe I'm due for an Atlas. :(
That's a 4.7 gearset (well, was... now it's about 15:1 with a lot of slip) inside a busted case.
For those wondering how strong is strong... the AP mainshaft (it's in some of the earlier pics in the same directory) survived.
I was thinking early on that this wasn't a torque-related break... but it appears that it might be after all. :(
did you hit that on something?
Scott, now having broken a toy case (was it 21 or 23 spline ?)
Would you still do toy cases or would you do a D300 or just go right for the atlas right off the bat ?
Thanks
more importantly........WHAT brand of gears were those?? AA or the total spline gears Marlin sells??
I'd say the case held up pretty well considering you've been beating on it in comps and trails with 44's for how long now, a couple years? It's just another testiment to how tough toy stuff really is.
Discussion Starter · #13 ·
They're early Marlin gears... from back around when the 4.0's had just come out, long long ago.
I was contemplating with some local friends on how much of a pounding those gears have taken.
Four broken mainshafts (two of them chromo)
One broken 60 front
Two shelled 9" rears
Three broken 44 fronts
Two or three broken driveshaft yokes
Several broken U-joints
It was in my V8 truck for two-plus years behind my NV4500
It went to Top Truck Challenge
It saw two (partial) years of competition in the current ride
I think it had a good life.
And I've already ordered another gearset from Marlin.
I still haven't determined if my slip-yoke-not-slipping theory holds water, or if it's an actual torque-only break. I can't wrap my mind around gears blowing out, taking the bottom off the case. So I'm stuck (mentally) on that it's gotta be a combo break.
As for what to use to fix it ahead-of-time... I dunno that a D300 would do it, without all the upgrades... and by then, with an adapter, you're nearly at the Atlas pricetag anyway.
So scott can you update us on the engine combo that your using now (for those of us who dont live on the board) I thought you still had the 5.0/NV4500/dual toy cases.
He never had that motor in this truck, you are way behind!:flipoff2: pretty sure he has a 2.0L saturn motor
Discussion Starter · #16 ·
This truck runs a 1.9L Saturn aluminum engine.
That is mated to a Toy G52.
First box is a 2.28 one.
MC07 into 4.7 box.
4.10 in the axles; 44" TSL's.
Previous truck had a 5.0/NV4500/4.7 single case. Never had a dual case with a V8 (and don't ever intend to).
MC07 into 4.7 box.
yeah, i got the same gearing, 4.10 axles, but im running a 4.7 case and an auto and thats it.
I am worried this will happen to me!! The axles aren't geared deep enough maybe and it is loading the output shaft heaps!?
Wicked Raciest !
One broken 60 front
You think!!!! Good job Scott!!!!!:D
1 - 20 of 27 Posts
