Here's the deal
I just installed a twin case set up in my 85 runner, I picked it up used so my foregone conclusion is that I kind of got screwed, but I think I can fix it with some help. The transmission is a G52 with an 84 case right behind it and an 85 case behind the adapter. when I'm bookin along in fourth or fifth gear and the throttle is just tipped in, it makes a pretty nasty grinding sound. it's a very specific situation, for instance just coming down a slight hill when I only need a little pressure on the gas, that's when it makes it, not when I'm accelarating or just cruising no gas. This very annoying. Sooo, I do have the old W56 tranny with a worn out 2nd gear synchro and a perfectly functioning, although high mileage stock t-case right behind it. Through my powers of deduction I think I've isolated the sound to the front most case, as when I move/pressure/wiggle the lever I can get the grinding to change pitches, and since I still have a fatty hole in the floor, my ear tells me that's the source of the noise. Question, will the t-case off my 56 bolt up to the 52, and if so, are the mods I have to do to it reasonable to do in my back yard shop (I have welder access) with Newbie experience? Thank you for your time
