1 - 6 of 6 Posts
after striping my ring gear,when reinstalling my r/D shaft after new ring and pinions. i noticed that the output shaft to the t/case wiggles about 1/8th inch or more up and down,side to side, is this normal?i have a vibration only when costing at high speed.is this the reason? thanx <IMG SRC="smilies/beer.gif" border="0"> <IMG SRC="smilies/usa.gif" border="0">
[ 11-01-2001: Message edited by: toy 4 rox ]
Wicked Raciest !
Originally posted by toy 4 rox:
<STRONG>after striping my ring gear,when reinstalling my r/D shaft after new ring and pinions. i noticed that the output shaft to the t/case wiggles about 1/8th inch or more up and down,side to side, is this normal?i have a vibration only when costing at high speed.is this the reason? thanx <IMG SRC="smilies/beer.gif" border="0"> <IMG SRC="smilies/usa.gif" border="0">
[ 11-01-2001: Message edited by: toy 4 rox ]</STRONG>
Do you mean the the output shaft is wiggleing up and down in the case? Or is it the normal play that is in the d-shaft? Did you check to make sure that the d-shaft flange nut on the t-case was tight. When I blew the R&P at JV this year and I kept on driving it back to camp the nut backed off a bit and the flange was loose and had slop in it.
<IMG SRC="smilies/usa.gif" border="0"> <IMG SRC="smilies/usa.gif" border="0">
Originally posted by OOPS:
<STRONG>Do you mean the the output shaft is wiggleing up and down in the case? Or is it the normal play that is in the d-shaft? Did you check to make sure that the d-shaft flange nut on the t-case was tight. When I blew the R&P at JV this year and I kept on driving it back to camp the nut backed off a bit and the flange was loose and had slop in it.
<IMG SRC="smilies/usa.gif" border="0"> <IMG SRC="smilies/usa.gif" border="0"></STRONG>
yes in the t/case.
1 - 6 of 6 Posts
