I have torn down the T case from my 40 and a spare T case I got from an HJ45. I would like to use the gear set form the 45 case because the high range range gears are wider. However, the dog teeth on the wider gear show more wear than the other set. Any opinions on which set I should use would be appreciated. Both transfer cases are single piece 4 speed.
TIA
Ben
TIA
Ben
