1 - 1 of 1 Posts
So I recently cracked the alum. housing on my sammy t-case so i swapped all the gears from my t-case (4:1) into a doner t-case, all seemed well, untill i tried pulled the truck out of the shop and tried to take it to the bush, dirving in two wheel, when shifting into third, the gears in the t-case slip and im stuck sitting in nuetral, the actual shifter stays in the 2 wheel drive position, but the truck wont move, same thing happends in 4 hi, didnt try going fast enough in 4-low, anyways im assuming i fawked up and didn't re-assemble the case properly.... has anyone had this happen before, any ideas as to what the hell i should look for before i tear into it again? thanks in advance.
specs. 89 sami, toy axles, yj's, 35s, gears, lockers...
1 - 1 of 1 Posts
