I need a yoke for the rear of my fixed yoke NP 208 case. I am under the impression by way of others that a NP 241 yoke will work as well. I dont know if a NP 205 yolk will work?? (yoke OD the same??? I it is the seals will work) I need a 32 spline yoke for a 1350 flange mount, with a 2 inch pilot hole. I know the above T cases are all 32 spline, but have no idea if the OD of the yoke that turns against the T case seal is the same. I have been informed these cvs were found on Fords, so maybe a 205 yoke will work????????????
