1 - 12 of 12 Posts
I have looked and cannot find one.
Anyone know where I can get one?
(8.4" diff)
Bones said:
Not available as far as I know. A friend welded his and sold the lock rite.
That is what I have right now (welded).
But I want the strength of a spool.
If I can get a set of 10 made would people be interested?
Probably about $200 a piece..
AL housings.. Unless steel is that much stronger..
Re: Tacoma
rochmpr said:
There are only 3 options for the 8.4" Tacoma rear axle, to date.
1) PowerTrax limited slip
2) ARB
3) Weld
by #1, do you mean a lock right? if not, you forgot a lock right. i have one in my T100. same axle, just 6" wider.
Aluminum spool:eek: :nuke: :nuke: Com Awn! If welded well, it's as strong as a spool, unless you ask CAMO:rolleyes:
Discussion Starter · #10 ·
We welded the side gears togetherand then added a plate on each side welded to the side gears.
Plus we added a tack weld to the pin in case it happens to shear (not likely but WTH why not)
BJ On Roids said:
i dont think a weld will hold up, ive broken what i thought would never come undone, but 6 months of street, 35s 38s and lots of wheeling
I've run welded allot, no problem with my dinky ass 38's;)
1 - 12 of 12 Posts
