1 - 20 of 50 Posts
I have a 2014 RAM 2500 4x4. I'm looking for a 35"-36" tall x 10" wide Aggressive , good riding on the H-way , quiet 10 ply tire , is there any such tire ? I have BFG A/T's now on 20" wheels but will change wheel size if needed . Don't like them anyway ! My wheels now are 10" wide , if I changed to a 8" wide wheel would a 12" wide tire fit and wear even ? Thanks for any advice .
Dinkerdoodledoo
Aggressive, quiet and good riding. Like fast, cheap and good in service, pick two, you can't get all three.
Most manufacturers say 8" min on a rim, but it's all tire dependent in a 12" wide tire.
I don't think I've ever seen a 35" tire that skinny. There might be an option for 19.5s in that size, but you won't find a light truck tire that tall and skinny. As far as rim width, lots of people put 12.5s on 8 inch rims.
I ran my two 12.5's on 7" wheels. I like em fat. :D
I run 295/70/18 nitto Terra grapplers on my dodge. Their as tall as a 35 and are 11.5" ish wide. Load E with a 4080lb rating per tire. They are kinda aggressive and ride awesome on the road.
Cooper just released their AT3 in a 285/75r18 e-rated, it's about 34.8 x 11.2.
Dinkerdoodledoo
i wanted something similar on my DMax and ended up with the Toyo A/T II "Xtreme" in the 285/75-17 size (34"x11"). they're fairly aggressive for an all terrain and ride smooth enough
This is what I have on my truck now.
Dinkerdoodledoo
285/70r19.5 will be everything you want and more.
Gavan, Ive got 285/70r17s on a stock 08 f350 dually and I know a 35x12.50 will fit as well. Most od the newer trucks have large wheel wells.
275/70R18
34” best I’ve found in a toy m55
its a stock size so affordable the tread is pretty durable. fairly happy with the wear and handling snow and ice no issue. most other larger sizes have a softer compound stock sizes tend to have more options and harder compounds for longer life kinda like the old 235/85R16 michelins the commercial fleets demand longer life span than the aftermarket
Toyo makes a 285/75R18 in an mt/rt/at. That's what I plan on running for the same effect. Basically a 35x10.5018.
20x10 is a large and wide wheel.........20" Load E rated tires will be very stiff
I think BFG KOs are junk for a DD/Tow Rig
I thought you were already running 35/12.50R20s
Why needing the change?
Why do you want something more narrow than a 12.50?
I'm running the toyo AT's in 285/75R18, they fit fine stock but a little tight with chains on the front so I added a leveling kit. The leveling kit also allow me to run my airbags up to 80psi and keep level with the camper.
1 - 20 of 50 Posts
