after breaking a rear pinion at cm05, on poison spyder.
i had to do the last mod on my SOA 60
parts and material;
2 1/2 johnny joint, from currie ind. $35.00
2x2x1/8 steel stock, roughly 5 feet long. $???? just lying around from previous slider job.
2 spring eyes from twisted up rear springs off my 60. basicly free.
one anti inversion shackle.$10. used
4 spring bushings from leftover set for my 60.$???
3/8 plate for axle brackets.$ steel stock lying around
x-member material
2x3x1/8 stock left over from slider material..$freebie
scrap diamond plate for gusset and misc. end capping $4.00
this was a copy of a single bar design.
the bar has a angle of 35 degrees
the eyelet span at the rear axle is 8" apart
with one eyelet in front of the axle and one behind the housing.
parts and material;
x-member material
