1 - 1 of 1 Posts
1976 FJ40 disc brake front axle
Lock right locker
4.56 gears
Late pattern pinion flange, also drilled for early pattern
Stock birfields (fine spline) repacked with moly grease
New seals and knuckle wipers
brake calipers included, clean but unsure of use-able condition
Stock hubs (warn)
New wheel studs
Housing shaved and cover armor added
Marlin Crawler steering stop and knuckle brace kit
Spring perches welded for spring over
Knuckles cut and turned for spring over and better pinion angle
High steer arms w/ tie rod and drag link (not sure brand, think Marlin)
Also have extra ring and pinion install kit and hub rebuild kit
Built this axle about 12 years ago and never got around to finishing it/using it. All new parts were new when installed. Has light surface rust on housing and end of axles (hubs not installed while stored). Was always stored indoors. Rotors still have masking tape on them from painting, that's why they're black.
Located in west Houston area.
$1500 OBO, will consider shipping at your cost
1 - 1 of 1 Posts
