1 - 5 of 5 Posts
Did a search & nadda. Is there a write up on how to extend the breather/vent tube on a TF-999 tranny? I know it's in the bell housing but not sure on how to extend it or where to drill the housing by the pump.
Thanks,
Someone on here has done this.
You have to plug weld the breather inside the transmission. Then you have to drill a new hole on top of the bell housing and tap in a fitting. Then you can run the hose where ever you like.
Mine's the crappy one at the bottom of the page (from the link above). We angled the copper tubing but then did it again going straight to the left and out a hole we drilled. It looked much better. Been through DEEP stuff and it works like a charm. :)
1 - 5 of 5 Posts
