1 - 14 of 14 Posts
I am hooking up my Art Carr and got to thinking about the kickdown cable. I have installed a transgo shift kit in the 727 that will hold or shift up/down to 1st and 2nd at any rpm, but will shift automatically in drive. My rig will be driven 90/10 in favor of the trail.
Do I really need the kickdown cable?
IH/Rover Moderator
BigHG said:
But I don't get the pressure part.
Why not sit down and read your shop manual?
IH/Rover Moderator
Hayraker said:
Hey OldScout, I don't have a manual. Would it be possible for you to take pictures of the remaining pages and post them for me?
:flipoff2: :flipoff2:
noyoucheapsuck:flipoff2:
Thanks Old Scoot for that fine read :flipoff2: but it really doesn't tell me much about the pressure other than it can be adjusted.
Being the slush box neophyte that I am, I am trying to uderstand the correlation of the throttle to the transmission. It would seem that with a full manual throttle body ( mine is almost) that I could shift this thing manually and it should not matter what the throttle is doing. If the engine is lugging when I hit the gas, I would downshift it just like a manual. Isn't that what the cable triggers , a downshift under load at lower rpms? Or is there more to it that I am missing. :confused:
IH/Rover Moderator
Are you really that cluesless? It tells you that the pressure valve works off of the movement of the kickdown lever! :rolleyes:
A full manual valve body is a racing mod and will ware out stock clutches 2x as fast. They run at full pressure all the time.
it controls line presure, difrent gear difrent clutches, bands applyed all requre presure
to little and you smoke the clutches/bands to hig and you blow seals.
please explane :confused: why do shift kits extend life then
quicker the sift less the actual rubbing betwen clutches = less wear
I can see a full manual valve body blowing hard parts cuz it such a hard shock blow when it shifts at WOT
its not only a hard shift at WOT, but all the time. ;)
get a np435 :beer:
1 - 14 of 14 Posts
