1 - 8 of 8 Posts
so i had my th350 rebuild and fitted with a tci rmvb with engine brake (32115)
the problem is when put in 1st or second, the trans locks up. reverse is fine.
had the same problem with the stock valve body so we swapped the case thinking it was cracked.
same problem. took it apart again, nothing wrong to see. air checked and all worked.
new converter, problem stays.
disconected the oil cooler. made it work for 2 seconds until i gave it some throttle.
any ideas?
so rebuild trans stock valve body
rebuild trans rmvb
different trans rebuild with same rmvb
all have the same problem.
called tci with no help
Discussion Starter #2
could it be that i would need a high flow oil filter with the manual valve body?
i'm using one that came with the rebuild kit
Is the linkage adjusted correctly? I run the exact same set up and if I'm not all the way in 1st when I shift into 2nd it will feel like something is dragging for just a second. Maybe try disconnecting the linkage and put in gear by hand?
Discussion Starter #4
tried that, same issue.
and to make things worse, i lost oilpresure:mad3:
There are a few different gaskets between the valve body and the Transmission. TCI RMVB requires a certain one. Your symptoms sound like you have the wrong gasket.
You should be able to see where the pressure has "indented" the gasket when you look really really really close. I believe if you just cut those areas out and it should be good.
I second this. Had same problem. The linkage adjustment is super finicky.
Discussion Starter #7
tried shifting it by hand, same issue. took out the manual vale body en put a stock one back in. drove for half a mile, when put in 1st, it shifted on its own to 2. when put in second gear something whas dragging a lot. when put in D she shifted 1-2-3 but very sloppy. took of the oil pan, lots of pieces inside and burnt oil. so back to square one. but stil don't know what the problem is
Did you ever get this figured out?
1 - 8 of 8 Posts
