1 - 7 of 7 Posts
The spline output and diamiter are the same on both, the 700's mane shaft is a bit longer and will need to be cut a little off the tail end.
They use the same adapter but the 700 is a longer trans so you will have to move around the crossmember and adjust the drivelines.
SCOTTS_4X said:
or you could support the board and buy one in the vendors section from john351c for half the price of an ORD adaptor ;)
-Scott
I guess I thought that funny yellow star by Stephen's name means that he is a vendor who supports the PBB. :rolleyes:
1 - 7 of 7 Posts
