This has got to be the coolest tech thing ever.
A Rover axle nut threads on perfectly to a GM hydroboost booster. I had cracked the GM nut while removing the old bracket, and the nut is forged from UndafawkobtainiumrightfromGM. So I was sobbing in my beer at my misfortunes and contemplating making another in the lathe, and I started looking for a suitable piece I could turn. I thought about a rover axle nut, and lo and behold it fit perfectly right on. Pretty unbelievable. Just tight enough, not too tight. The threads are a perfect fit.
Anyways, so it just got like soo much easier to install hydroboost on a Land-Rover as you can ditch the ghetto nut and bracket and just build an attachment plate with a 1.?? hole and bolt it up with a rover stub axle nut.
That is all.
That is all.
