The BillaVista 60
Bomb Proof Dana 60
Part 4 - Crane High Clearance Alloy Steel Indexed Steering Knuckles
By BillaVista
The BillaVista-60 Super Dana 60 Front Axle Project
Go to -->
Introduction
The baddest front Dana 60 on the planet should of course have the baddest steering knuckles on the planet, right? And of course it does
But seriously - hardcore abuse, and especially the stress of full hydraulic steering with high-steer pushing big tires around in the rocks can cause stock Spicer steering knuckles to fatigue, crack, and break apart - especially 20-30 year old knuckles.
Photo courtesy of Camo
The pic above shows the usual failure mode of the stock type knuckle. Reportedly, Ford knuckles are even more prone to this type of failure than Chevy and Dodge types.
When all those factors are considered together, there emerges one clear winner:
The Knuckles
I chose HSC (High Steer Crane) 60 Knuckles from Crane High Clearance.
The HSC 60 Knuckles are absolute works of art.
They are designed as replacement knuckles for Chevy/Dodge style Dana 60s. You can see from the pic the 6 bolt non-concentric GM spindle bolt pattern, and the semi-circular "indentation cutout" (arrow0 for the large single piston GM/Dodge style brakes.
Massive chunks of cast Nickel-chromium-molybdenum alloy steel.
DO NOT confuse the term "cast" here - it is not short for "cast iron" as it is so frequently used, it has nothing to do with the material - it is the process by which the material is made into the useful shape.
This is very important, because WAY too many people misuse the term, and will be heard saying things like "I prefer steel to cast, because a cast part like that will just crack/shatter when it breaks, whereas the steel will bend".
This is, of course, a gross misunderstanding of the facts, and is completely erroneous.
The knuckles will physically fit on Ford axle end forgings (inner knuckles or C's). But the user would have to swap to GM parts or go custom with:
Of course, this may be an ideal upgrade anyway, if you're swapping to 35 spline Cr-Mo axles at the same time, since you can just swap to Chevy stub shafts.
The material is ASTM A487. Nickel-chromium-molybdenum alloy steel. The equivalent SAE 4 digit code for this material that we are more familiar with would be 8630.
That means it's like the chrom-moly alloy steel we are more familiar with - but with the addition of Nickel as a further alloying element.
The exact specifications are as follows:
Perhaps a quick review of alloying elements is required:
Here are some yield strength numbers for comparison, taken from Taken from the 24th edition of the Machinery's handbook, table 9 - Typical Properties of Selected Carbon and Alloy Steels.
1030 being a typical plate steel.
Recall that Yield Strength is the point at which a material exhibits a strain increase without increase in stress. This is the load at which a material has exceeded its elastic limit and becomes permanently deformed.
1030 normalized 50,000 psi, annealed 50,000 psi, quenched and tempered (1200*C) 64,000 psi
Comparing the numbers for normalized, we see 50kpsi vs 85kpsi - that's a 70% greater yield strength!
It's clear then that this is a vastly superior material to the plate mild steel or nodular cast-iron that other alternatives are constructed from.
In addition to the superior material, the process of casting the steel eliminates the need to weld any parts of the knuckle together and therefore eliminates stress risers in high stress regions. Also, in a fabricated/welded part you have to be concerned with not only the selection of base steel and welding process but also what edge treatment is used to eliminate the slag, sharp edge, and maximize surface finish; what post weld heat treatment/stress relieve is used to minimize the residual stress from the welding process; and all of that has to be perfect - every weld, every time - and still you won;t match the strength and uniformity of a cast alloy steel part.
The casting also produces a product with an even, consistent surface finish that is extremely important in preventing stress raisers at the surface. Remember, stress raisers lead to the formation of tiny cracks that will eventually lead to fatigue and failure of the part.
In addition, these knuckles can easily be welded, whether for customization or emergency trail repair (like you're ever going to need that!).
And finally, casting the part allows for optimum, consistent fillet radii in the transition zone between planes (translation - smooth curves allow stress to flow and not bunch up and break things) as shown by the blue arrow - without expensive and time consuming post-production machining.
So we have so far, a part that is superior to all other in material and manufacturing process, but what about design?
Most notably, there is the huge increase in strength and fatigue life created by the increased web and flange thickness. A stock Chevy Dana 60 knuckle weighs approximately 16.5 pounds. The Crane knuckles weigh approximately 22 pounds.
When material, process, size and shape are all taken into account it is extremely reasonable to estimate that these knuckles are at least twice as strong as stock knuckles.
The post-casting machine work is also top notch.
But by far the greatest innovation of the Crane knuckles is the integrated high-steer indexing system.
There is a raised indexing tab cast into the top of the knuckle. This allows for use of a matching slot in the underside of the steering arm. If the parts are fit together closely enough, this ingenious system relieves the fasteners of the shear load caused by steering forces.
This indicates how the steering arm and knuckle are "indexed" together, creating the strongest possible joint at this critical place.
The idea is so simple yet brilliant, it leaves the rest of us smacking our heads and muttering "Why didn't I think of that?"
More on the closeness of fit and steering arms later on.
Continuing in the theme of excellent, innovative features that prove that Crane not only listen to customers needs, but as wheelers themselves understand what we want, the Crane knuckles have this excellent feature:
Dual steering stops, as indicated by the arrows. This allows not only finer tuning of turning angles, which is critical with hydraulic steering and big axles/u-joints (like my Superiors and CTMs), but also a stronger steering stop system, as two sides will be working together to prevent further turning at full lock, in either direction. This is again critical with powerful hydraulic steering, and is key to preventing binding and possible destruction of axle yoke, u-joint, and knuckle itself as happens when the knuckles are over-steered.
Here's a shot of the complete knuckle and steering arm package from crane.
The knuckles and steering arms are shipped uncoated, and must be painted or otherwise coated prior to assembly and installation.
I used a 2 step process that has worked well for me before (and that is all rattle-can - no painting gear needed).
Step one is to prime the raw steel parts with a high quality zinc rich self-etching primer. Not to be confused with cheap grey primer - this stuff is 2-3x more expensive but is the only stuff that will properly adhere to the raw steel.
And for the top coat I chose a groovy silver to show off the parts. This is "Detroit Diesel Silver" industrial coating from Bowman.
And finally, if there was any doubt left at all about which knuckle is the strongest - consider this:
There is a professional Mechanical Engineer who is a member of our little tech discussion family over at the Pirate4x4.com bulletin board. He goes by the online tag of lt1yj. I'll let him introduce himself, using his own words taken from a forum post he made:
Compared to the stock knuckles
The extra beef is immediately apparent when the stock knuckles are compared side by side. A stock Chevy Dana 60 knuckle weighs approximately 16.5lbs. The Crane knuckles weigh approximately 22 lbs!
The Crane knuckles also use 9/16-18NF threaded holes for retention of steering arms / upper kingpin caps.
Assuming a grade 8 fastener, this represents an increase in available clamping force of about 300 ft/lbs, an increase in maximum tightening torque capacity of 30 ft/lbs and an increase in shear strength from about 23,500 lbs to 29,800 lbs, or 21% per fastener.
The lower bearing retainer threaded holes are the stock 1/2-20NF and stock spicer bearing caps are used, along with stock kingpin bearings and rebuild parts .
The area indicated by the arrow is the critically stressed area on a Dana 60 steering knuckle. This is where the stress concentrates as the steering forces act to try to twist the top of the knuckle off.
Notice not only the significant increase in material in the Crane knuckle, but also note the radius at the transition, chosen to minimize stress concentrations in the part.
Every area possible is beefed up compared to the stock parts.
Note the extra wide vertical "rib" , and the beefy steering stop in the Crane knuckle.
For those using high-steer, the elimination of the useless stock "steering arm" gives a nice clean appearance to the knuckle.
However, the Crane knuckles are available in "classic" form, with stock Chevy location steering arms and stock 1/2-NF threaded holes for the kingpin cap bolts/studs.
These "classic" 60 knuckles from crane also do not feature the high-steer indexing system, and can easily be used with any existing dana 60 High Steer Arm.
The Steering Arms
Now we come to the Crane Indexed Steering Arms. These are a brilliant idea, the execution of which is in need of some improvement.
Here we see the basic design of the arm. The arms are machined from a single piece of mild steel that is initially 1 inch thick.
They fit over the kingpin bushing and spring, and have a separate cast aluminium cap. The attachment holes are straight-cut holes for 9/16" bolts.
Thickest side of arm is 1 inch thick.
Thinnest side of arm is 5/8" thick.
They have an angle machined into the steering arm, that is intended to allow the "cancellation" of the stock kingpin inclination angle, resulting in a horizontal surface for the steering linkages rod end attachments. The theory is, that by doing so, regardless of whether the steering linkage uses Heim joints or standard automotive tie rod ends - by having the steering arm horizontal at rest, the least amount of valuable misalignment angle available in the joint is consumed in it's static mounting position.
This in turn would leave the greatest amount of misalignment angle available for accommodating suspension travel without binding the steering linkage.
The theory is sound, and a good idea, but the problem is, if you do this, BOTH sides of the steering arm must remain parallel to one another - which they do not in the Crane arms. This is because the head of the bolt and the nut must be parallel to one another, you can't have either trying to seat against an angled surface (in the case of a TRE, the tapered stud and nut must be perpendicular to one another - the result is the same) and therefore - the 2 sides of the arm must be parallel.
If you machine an angle into one side of the arm, as in the Crane arms, you have to cut a slot for either the nut or the head of the bolt.
This is what I had to do mount the arms, but is not a particularly good solution for 2 reasons:
The much better way to eliminate the stock kingpin inclination would be to start with a much thicker piece of steel and mill both sides the same angle, eliminating the angle, but leaving full thickness (an inch or so) and both sides of the arm parallel to one another.
If it were determined that this approach would involve too great an expense in material and time, personally I would much prefer to simply have flat 1" thick arms, rather than having them 5/8" thick around the hole and having to mill a slot.
There is one neat benefit to the "machine slot" approach though - you can machine the slot just big enough for the bolt head and then not require a tool on the head of the bolt during assembly or disassembly.
Finally, the machined angle presents one last potential problem area. And that is the very limited thickness left in the arm, right were the indexing slot overlaps the arm where it is angled (yellow arrows).
Unfortunately, this happens right where there is a major section change from the "body" of the arm to the arm itself. As it is, this will be a highly stressed area as the steering forces attempt to try and twist the arm off here.
The result is, the machined angle leaves one side of the arm just 5/8" thick, and then on top of that, the indexing slot in the arm removes even more material (I forgot to get an exact measurement, but it's probably about 1/4" deep) leaving the arm only about 1/2" thick at the thinnest part.
We shall see how they hold up, but this doesn't seem enough for my tastes, and the prospect of a steering arm failure on the trail is not a thrilling one.
Installed on the knuckle the arms look like this.
This side looks just the job...
...but the "thin" side looks, well, not as beefy as it could, and probably should, be.
As for retention, the arms themselves are retained with four 9/16-18NF fine thread SAE grade 8 bolts and lock washers.
The 9/16" bolts are an upgrade in size from the stock 1/2" fine thread, but the straight holes in the arm and separate cap result in a lack of a true zero-clearance fit for the fasteners.
Without either tapered nuts (as in stock D60 hardware) or tapered, split cone washers (as in D44 style hardware) there is a possibility of loose fit around the fasteners, leading to relative motion between arm and knuckle, fatigue, and possible bolt failure.
Of course - in this regard, the Crane arm and knuckle combo is unique, and so the normal rules and concerns don't apply exactly as they do to other arm and knuckle joints.
The ingenious indexing system, consisting of the cast chrom-moly key on the knuckle and the matching slot in the steering arm combine to ensure the strongest, slop-free union possible in a joint of this kind.
The official tolerance on the difference between the key and slot is plus or minus 0.001", with the slot being just very slightly larger than the key. Technically this is known as a transitional class fit.
In practice, the mating between arm and knuckle key is close, but not what I would describe as "tight". The arm drops over the key with no persuasion required for assembly. Once on the knuckle, with key indexed in slot, but no bolts installed, there is just the teeny-tiniest perceptible wiggle. Install the bolts, without even tightening them ,and the whole joint is tight and wiggle free.
I have no practical concerns that there will be relative motion between the arm and knuckle once installed and torqued to spec - but, theory says it is possible, particularly if the bolts loosen somehow. And we are talking about a desire for the "best" - the ultimate. With that in mind, I would personally prefer to see the key/slot fit be a true interference fit (with the slot being 1-3 thou smaller than the key) and the joint require slight force or heating for assembly.
So in summary, we have:
Advantages:
Areas for improvement:
Overall a good first design from Crane, with an innovative and extremely useful indexing system, that could use some refinements.
* BREAKING NEWS *
Here's the really cool thing - I shared all of these initial opinions of mine with Tim Plamondon, one of the key players at Crane High Clearance (who is, incidentally, a fourth or fifth generation pattern maker [that's a dude who makes things from molten steel!], a heck if a nice guy to talk to, with a keen interest, super technical ability, and great customer service)
I also shared with him a few other observations and design ideas I haven't yet published here, as he has agreed to work with me in designing and developing the ULTIMATE D60 high steering arm, one that can truly take it's place beside their great knuckles.
Stay tuned - I will post results, impressions, and more testing here as the project progresses.
Installation
As I mentioned in part 2 of the BV-60 article, my intent was never to make this article a detailed installation article - I'm assuming that we're pretty comfortable with axle R&R at this stage. However, should you wish to review or study detailed information regarding the building of a D60 front axle particularly swapping knuckles on a Dana 60 front axle, that information is readily available in several places right here at Pirate4x4.com. You can check out:
My detailed article that covers the whole process at:
Dana 60 front axle kingpin rebuild
Or, for more general dana 60 information:
The original Spicer D60 front axle maintenance manual
The one ton axle tech manual compiled from US military manuals
The Dana light axle service manual (torque and setup specs)
The Dana 60 Bible
With that - here are some pics and notes from the installation of the Crane knuckles on the BillaVista-60.
The 6 new spindle studs are installed in the knuckle, and the knuckle installed on the axles end forging.
Kingpin nylon bushing installed in top of knuckle
Superior cr-mo axle installed.
Here's a little something I, as usual, didn't anticipate.
I have a "custom" front brake setup on my front Dana 60. Instead of the stock brakes, I use a 3/4 ton calliper and rotor, that requires a custom calliper bracket. This custom bracket is really nothing more than the grafting together of 1 ton and 3/4 ton brackets.
However, because if the extra beef of the Crane knuckles, at assembly time, I found my custom bracket would no longer fit flush against the spindle, due to slight interference as indicated by the arrows in the pic above.
Slightly closer view of the area in question. As you can see in the pic, I ground down the calliper bracket as much as possible, but in the end....
I just had to take my 4.5" mini grinder and "tidy up" the knuckle just a tad.
You know, I discovered you really don't know what kind of (wo)man you are until you have to take a grinder to almost $1k worth of brand spanking new chrom-moly knuckles!!
But it was really just a very light smoothing, and I should emphasize, certainly no fault of the Crane knuckles.
If you have stock 1 ton brakes, everything will fit like a glove, no grinder required!
But if you do have some sort of custom brake setup - you should be aware of the possibility....and prepare yourself psychologically
Here we can see everything is tidied up nicely and I'm back in business.
Custom brakes fitted up, big fat Cr-mo knuckles, axle shafts, and U-joints
Ohhhh yeaaaa baby!
Steering stop being adjusted and tested. I used a grade 8 bolt with an extra nut for locking.
Un-machined steering arms being test-fit. You can clearly see the angle in the arm cancelling the kingpin axis inclination.
Kingpin spring and spring retainer installed.
Kingpin cap being installed
The finished package, ready to rock.
Crane High Clearance Extreme Diff Cover
There are a lot of diff covers on the market, ranging from re-boxed "thick" stock covers, to welded together products and all the way up to the king of them all - the Crane Extreme Diff Cover. Naturally, in keeping with the theme of building the BV-60 to be the best, I wanted the best diff cover money could buy - and I chose Crane. Here's why:
The kit comes with diff cover, socket-head style fill plug, button-head mounting bolts, sealant, and instructions.
Nothing is second rate - the bolts themselves are top of the line. They are Holo Krome® button-head bolts that are far stronger than a regular SAE Grade 8 bolt. In fact Holo Krome is one of only 2 SAE brands recommended by that perennial godfather of engineering tech and quality - the late Carroll Smith.
Even the sealant is not some cheap throw-away generic tube. You get a tube of The Right StuffTM RTV - one of the best on the market, and my personal favourite next to the factory GM stuff.
Cast as a single seamless piece of chrom-moly alloy steel, this is unquestionably the strongest diff cover available. There are no seams, no welds, no heat-affected zone stress raisers - juts one piece of bulletproof chrom-moly steel.
The design is also important. Built to be abused for a lifetime, and specifically for hardcore 4x4 use, the diff cover is lipless - leaving no edges to catch on the rocks. It also has the fill plug in a raised location, allowing for plenty of lubricant in the diff - which is great for raised pinions common in 4x4's. Due to a low chasis height' the Wolf's pinion isn't radically tilted, but the extra capacity offers great cooling and lubrication.
The steel cover is also fully machineable and weldable. It was designed specifically to accommodate our many different needs - from welding on mounts (like a steering assist cylinder mount) to shaving - it is designed so that you can easily customize it.
Of course, the real deal is in the beef. A good 1/4" thick at the flange, and thicker throughout the body - you're not going to be punching a hole in this cover.
And, if by some freak you do break the cover - it is fully covered by a lifetime guarantee on workmanship and materials. When I spoke personally with Tim at Crane High Clearance, he said "If you break one of these, we will replace it, period. And be sure to post pics, because that carnage we have to see!"
The cover bolts are nicely recessed and protected in their pockets.
Crane offer "stainless steel" bolts on request, but personally i would advise against them. Though I don;t know the specific grade of stainless they use, in general stainless steals are much weaker then non-stainless alloys - usually somewhere between grade 2 and 5 on the scale. I'd stick with the very groovy Holo Krome® bolts.
The cover comes unfinished - so you have to paint or powder coat or finish it to your liking.
I painted mine with a quality zinc self-etching primer first (essential to get proper adherence to the raw steel), and then top coated them with Bowman "Detroit Diesel Silver" Industrial Coating (spray bomb!)
Here's the mangled beast it is replacing. You can clearly see why I need the strongest cover available. I like to drive by feel!
Think about it, your diff cover is way out there in front - first to meet the rocks, and covering the heart of your axle, the diff. It HAS to be strong.
Look at all the various pieces of 1/4" steel welded to this Frankenstein creation in an attempt to protect the diff.
The only trouble is, no matter how much steel I welded on, I was left with the weak, flimsy lip that was never designed for the abuse I dish out. You can see here I have peeled, bent, and ground it into oblivion.
It will be so nice to not have to worry about peeled covers and dripping gear oil anymore!
Of course, my front diff is no longer to "factory spec", the rocks and my 4.5" mini-grinder have both conspired to grind down the housing bottom over the years.
Crane anticipated that, and included in the instructions guidelines for trimming the Extreme Diff Cover to match. It's so nice to have products professionally designed and manufactured by folks who 'wheel and understand our needs too.
I marked the offending overhang with a permanent marker while the cover was installed, then removed the cover.
And put to work the 4.5" mini-grinder with thin zip-disk cutting wheel attached; to remove the overhang.
Once that was done, I installed the cover. Unexpectedly I hit a snag. One of the cover bolt holes wouldn't line up with the housing. Uh-oh!
It wasn't off by much, just a hair. Damn! I tried several things - made sure all the other bolts were loose, reinstalled the cover twice, and even matched it up back-to-back with a stock cover to make sure my housing wasn't tweaked or warped.
The hole was off a touch - but no big deal, I just opened it up with drill, about 1/16" was all it took - not even enough for me to use a washer under the bolt head.
The BillaVista-60 now has some seriously beefy protection up front. Brute strength, no lip to catch and bend, leak free, rounded bolt heads to minimize rock-rash, extra oil capacity, and a lifetime guarantee. Like Crane's company motto says:
ABUSER FRIENDLY!!
CUSTOMER SERVICE !!!
Naturally, I spoke to Crane about the misaligned bolt-hole. I told them it wasn't a really big deal, but a minor frustration, and suggested maybe they might want to check their Quality Control procedure.
Their response was quite unexpected.
First we shared a laugh at the irony - not one other cover has had a reported problem - why did it have to be the guy with the big mouth and the blazing keyboard?! Then this is what they said:
Go to -->
Contact Info:
Get a GoStats hit counter
Bomb Proof Dana 60
By BillaVista
Go to -->
- Part 1a - The Tech Behind the Talk - Steel and Material Strength
- Part 1b - The Tech Behind the Talk - Axle Shaft Technology
- Part 2 - Superior Shafts and CTM Joints
- Part 3 - Polyperformance Drive Flanges
- Part 4 - Crane High Clearance Knuckles, Steering Arms, and Diff Cover
- Part 5 - Selectable Locker
- Part 6 - Testing and Summary
Introduction
There were several criteria I examined when selecting my new knuckles. Brute strength of course, material selection, manufacturing process, quality, manufacturers reputation and warranty, steering options and features, and whether or not the knuckle can be easily machined or welded either for customization for emergency repair if necessary. Notice that I didn't really factor in price - this article is not about the "most economical" or "cheapest" Dana 60 - it's about the best, and that's what I tried to choose."In the case of these knuckles the failure mode is the result of torsional shear stress at a sharp discontinuity. In other words the steering forces are trying to twist the knuckle about the king pin axis between the top flange and the spindle. Just below the top flange there is a large change in cross section. Right at that change in cross section the shear stress increases dramatically (stress riser or stress concentrator). Add a little impact to the equation and the stresses go through the roof. Any sharp notch will hasten the failure." - ltiyj, P. Eng, ME, PBB member
The Knuckles
- brakes
- spindle, wheel bearings, and hub
- stub axle
- Tensile Strength 105-130,000 psi
- Yield Strength 85,000 psi
- Brinell Hardness 235
- Percent Elongation 17%
- Chromium - Increases corrosion resistance, hardenability and wear resistance
- Molybdenum - Deepens hardening, raises creep strength and hot-hardness, enhances corrosion resistance and increases wear resistance.
- Nickel - Increases strength and toughness
Here's the thing. Lt1yj has offered:"I make my living (running my own business) evaluating failures and the best way to modify the design to minimize the failure mode. My bread and butter is welded structure fatigue.
I use a process called finite element analysis that takes the full part in 3D (computer model) and breaks it into small "bricks". These bricks are put together to make the "virtual" part on the computer. I then add mathematical relationships that describe how the part is held in place in the real world, and finally add the real world external loads. The computer will spit out a pile of data and I "look" at it on the computer.
It can show me how the part bends and where the high stresses are located. It's up to me to try to understand why the part is behaving like it is and how to modify the geometry to improve local stress risers.
The computer program I use is one of the very high end packages that cost in the $60-80K range to purchase. Companies like Caterpillar, Harley Davidson, Ford, John Deere, Case, etc use it to study impact, roll over protection structures, gear tooth contact, pin linkage assemblies, etc."
To date, only one manufacturer has stepped up and offered the information for the test.....Crane High Clearance!"If the board/manufacturer's want an accurate assessment of these parts I can clear up any doubt in about two weeks time. All I need are the prints/solid models of the parts, true stress/strain curves and the design load cases. I'll run them in Abaqus full nonlinear material plasticity (non failure) to show where the failure will occur, how much load it takes and what deformation occurs before the section goes fully plastic. Throw in the stock part and I can even tell you what the increase over the OEM design is.
I will use the same boundary conditions, same forces, same mesh density for each model. I will limit the total model size to 1.2 million degrees of freedom only because that is equivalent to an 8 hour solution for a single load case.
I have no doubt what the outcome will be, but it will give me the ability to put a number on it."
The Steering Arms
- The removal of material and therefore potential weakening of the arm, right where the concentration of stress is high and you want it to be strongest. In order to have parallel surfaces for nut and bolt head, the slot has to be cut to a depth equal to the thinnest part of the arm - which is only 5/8"
- You can't properly machine the slot yourself unless you have the proper machine tools. This complicates the matter slightly from just having to bore the correct diameter hole.
Advantages:
- Brilliant indexed system - exactly what a joint of this nature should have.
- Beefy 9/16" sized hardware
- Cool cast aluminium cap
- 1" thick steel "body"
- Index system fit should be tighter - a true interference fit
- Arm itself should be no less than 1" thick at its thinnest point
- If inclination cancelling angle is to be used, it should be machined into both sides, so arm isn't thinner on one edge and so that bolt head and nut are parallel.
- For optimum design - fastening system should incorporate studs and some sort of tapered fit (washer or nut seat)
* BREAKING NEWS *
Installation
The Dana 60 Bible
Ohhhh yeaaaa baby!
ABUSER FRIENDLY!!
I think that's superb customer service, and speaks volumes about the company. It's why I love to deal with the small, independent guys. There's nothing better than a company that truly stands behind what it says and does. They made no excuses, offered no bull, demanded nothing from me - not proof, not the other one back - they simply took me at my word (and photo of course) and made it better than right. I respect that, a LOT! It's far too rare these days, and I ALWAYS want to do business with companies like that. Good on ya' Crane!"As a fledgling company we will not compromise on our quality. We are out to set the the standard by which others are measured in this very competitive market. We will send you a replacement cover, that is our policy if anyone is unhappy with our product, this not just special treatment for you. We sincerely apologize for any inconvenience. Our goal of 100% customer satisfaction will be obtained by offering the finest products available with a lifetime guarantee." ~ Chris Crane.
Go to -->
Contact Info:
Poly Performance Offroad Products 725 Buckley Rd San Luis Obispo, CA 93401 Phone: 805-783-2060 YOUR OFF-ROAD PARTS SOURCE! | POLY PERFORMANCE | CTM Racing Products, Inc. 32991 Calle Aviador #E San Juan Capistrano, CA 92675 Phone:. 949-487-0770 Fax: 949-487-0772 Landing Page |
Crane Hi Clearance Phone: 303-917-4851 Crane Axle 4x4 Off-Road Knuckles, Diff Covers, and Axle Parts | Superior Axle and Gear 1477 Davril Circle Corona, CA 92880 Phone (888) 522-2953 Fax (888) 747-2953 http://www.superioraxle.com/ |
