1 - 3 of 3 Posts
Discussion Starter · #2 ·
THE BEST BJ EVER
Year / Model Part No. Price
03-10 2500/3500 4x4 CS-DBJP $800
03-10 2500/3500 4x4 Megacab CS-DBJP $800
03-09 1500 4x4 Megacab CS-DBJP $800
Dodge Ram Suspension Multi Rate Coil Springs
In our multi-rate springs each coil is spaced differently making them a variable spring rate. Initially it is easy to compress these springs for the first couple of inches. As you apply more force, the coils come closer to each other. After a certain point, the coils at the bottom 1/4 of these springs begin to touch each other and finally become inactive or dead, which makes the spring stiffer. The more force you apply to our multi-rate spring the more the rate increases. So, these springs are compliant to very small bumps on the road, while achieving control when needed off road, hard braking, and turning. These springs allow you to achieve the highest performance while driving hard and providing a smooth, comfortable drive the rest of the time.
DODGE RAM FITMENT GUIDE
94 - 09 2500 / 3500 4x4 (Diesel multirate)
03 - 09 2500 / 3500 4x4 (Hemi multirate)
03 - 09 1500 Megacab 4x4 (Hemi multirate)
SPECIFICATIONS
3.0 inches of lift
Shot peened and pre set
$440
1 - 3 of 3 Posts
