1 - 20 of 372 Posts
in an attempt to go fast, crawl, haul myself and crap to the dezert/mountains/wherever for the weekend, all while looking cool heres a quick rundown of what i got going on
front axle
- diamond 8.4
- booger brakes putting me at 66 wms
- longfield inner, 30spline, and hub gears
- 5.29s with a detroit
- arp hardware from front range
rear axle
- stock rear 8.4 (64" full float diamond waiting)
- arb 5.29s
- 1.5" wheelspacers
engine
- stock 3rz
- k&n intake
trans/tcase
- 3rz bell housing, w56, mini truck reduction housing, marlin T-360, 23 spline v6 taco case
- front range offroad center place
front suspension
- 16" 2.5 fox coilovers (should of used 14", pita to package)
- will update with spring rate when i get it figured out
- 2.0 airbumps
- strapped at ~14" of vertical travel
- 2.0x.25 wall lower links, bushing at the frame, 1.25 hiem at the axle
steering
- howe tc pump on custom bracket
- flow through aluminum cooler
- gm y steering kit from addicted offroad
- stock steering arms, reamed for chevy ends
- stock box
- fror firewall plate
rear suspension
- f55 deavers, frenched into the frame
- total chaos 12" shackles mount on the top of the frame
- full boxed rear frame
- 3.0x10" fox smooth bodies mounted on a link arm, around a 60% motion ratio
- 14" of travel
wheels/tires
- Cragar Chrome Soft 8 Wheels
- 17x8 4.5 bs
- 35x12.5x17 general grabbers
other junk
- hardmounted body
- 1.75x.120 cage front to back, some 1.5 and 1.25 tossed in
- 2 hella 4k hids
- 1 hella 4k euro
- lowrance 7200 gps
- 32gal jaz jeepspeed cell
- stock fuel pump/sender mounted on a custom plate
- steel braided brake lines from g&j aircraft
- kartek seats
- crow reverse pull padded harnesses
- cab swap
only thing from the orginal truck is the frame with a slightly bent passenger frame rail and the motor ... haha
the beginning
Mobil1Syn is Building a Truck
Captain Coconut isn't taking the initiative to start a build thread on his truck, so I'm doing it for him.
Welcome to REV_B of the coconutmobile.
Truck is a '95 Tacoma. 3rz 5 speed. Only details I know of the build, is that the IFS is torched out, and this pic he sent me tonight.
http://www.pirate4x4.com/forum/attachment.php?attachmentid=472341&stc=1&d=1255583717[/img[]
[img]http://www.pirate4x4.com/forum/attachment.php?attachmentid=472340&stc=1&d=1255583717
Sweet, nice to see a new build.
hahaha awesome
i'll give an update: frame got stripped and boxed last night from the cab back. i took a whole bunch of pics of chris "stackin dimes" but he left the camera at the shop
No solid axle for me. I'll just kick his ass in the desert and stay away from the hammers.
this thread is not complete without a pic of the UNO MIG responsible for all welding done on Rev A of the build
let's see . . .
Diamond front with 8.4 diff, linked front, 62" deaver rears, and mismatched 33" mud tires.
All the pics I get are of his hotass sister though??
This is hard work updating someone else's build thread. I wonder if he hasn't found this yet, or if he is ignoring us. :confused:
this thread confirms it, i may be dyslexic. every time i keep reading unimog.
It's about Fawkin time we see this thread pop up. If he takes any longer, it will officially be a longer build-up than the 50% 2wd-4wd conversion. :flipoff2:
What kind of an equipment list are we gonna see? What kind of T-Case, driveshafts, etc.
1 - 20 of 372 Posts
