1 - 20 of 59 Posts
<IMG width=478 height=298 SRC="http://www.pirate4x4.com/ubb/uploads/avcorners.JPG">
this is the yj so far with the avalanche corners and rockers, and bds 4 inch front waggy springs in the rear and yj4 inch front both soa. d60 front 14 bolt rear, and 15x10 with 37 boggers. the wheelbase is now 97 inches
There you go, that is awesome. I am starting a smilar project. What engine/trans/t-c are you running? Does that 14 bolts come close to the gas tank at all with the waggy springs?
91tbi 350/th350/d300 with 32 spline output. the 14 bolt is under the tank a little but with all the lift i dont think it will even come close.
Cool deal. I figure a D60 will clear without a problem. I want to run 38 sx's to start out and working my way to 39.5 boggers. initially i think i can run front waggy's all around with an S/R and a 1" body lift to clear the 38's. i'm not planning on fenders either. based on what you've done to yours, do you think I will have any clearance issues? i'll be sure to use a bumpstop. also, is you d300 clocked at all? i also plan to cut the tunnel and clock the d300 flat. keep me updated on the project.
<IMG width=482 height=330 SRC="http://www.pirate4x4.com/ubb/uploads/d300.JPG">
<IMG width=458 height=236 SRC="http://www.pirate4x4.com/ubb/uploads/d3002.JPG">
Discussion Starter · #9 ·
<IMG width=438 height=364 SRC="http://www.pirate4x4.com/ubb/uploads/momotor.JPG">
heres the motor
Hey Where Did you Get those Bad Ass Pulley's And Brackets ???????? I want To Know !!!!!!!
Adam,,,,,, And How Much Are They???????
Discussion Starter · #11 ·
march and there like $500
yjtj...what are you doing about front d-shaft to transmission pan clearance???
On mine the front shaft just about hits the pan, I couldn't use a cv shaft up front cause it wouldn't bolt on <IMG SRC="smilies/confused.gif" border="0">
Discussion Starter · #13 ·
i will need to use a stock width d shaft like 1 1/4 and i wont fit a cv either. it will come close but i have enuff play prolly due to the t case not being totaly flat and the amount of lift i have.
Discussion Starter · #16 ·
mrt 18 bolt 15x10
Any problem clearing the brakes w/ 15" wheels?
Captainflex, I have S.R. and waggy front packs all the way around on my CJ7, with TJ flares I have no problem clearing.
-xBabyJesus
1 - 20 of 59 Posts
