1 - 6 of 6 Posts
Is there only one 8 lug pattern? Well spacing I maen. Nothing like 5x4.5 and 5x5.5 stuff right?
Basicly I want to make sure 17 inch Hummer H2 wheels will work for my axles from a 94 Ram 2500.
The lug pattern is the same GM and Dodge, it is the newer Fords that have the metric pattern. Be sure that the caps to the wheels will not hit your full floater axle in the rear befor you buy them.
Also watch that the center hole is big enough to go over your axle..Gm normaly uses a wheel with a smaller center hole than Dodge..The center hole for a Dodge should be 5 inches whereas Gm is some where around 4.5 inches..
1 - 6 of 6 Posts
