I know its been done using Ford TTB stuff because ive seen one on here somewhere before. anyway, does anyone see any problems i may run into when doing this.
the thought process of this it to take a TTB D44 hi pinion thrd. make a casing from .5" steel that holds the axle tubes up to the sides of the 3rd and use some chevvy D44 shafts only switched sides (i realize the D44 thrid is different than other 3rds because it encapsiates the carrier and gear all the way to the cover). anyway, i think it could be strong enough with some gusseting on the tubes, and maybe a decent truss to keep the tubes true.
i have seen it where prople have welded their TTb together to creat a solid axle type thing. if you have pics of this please post up.
Callen
Callen
