1 - 4 of 4 Posts
I have been toying around with the idea of selling my rig before it gets destroyed and isn't worth anything. Below are a list of stats and parts...I can email pics to anyone who might be interested....
91 Jeep Wrangler 82xxx original miles
--Engine
349 Stroked Ford small block
Eagle 4340 forged crank
Eagle I-beam rods
Ross custom dished pistons 9.5 Comp
C&A rings
Clevite H bearings
balanced and blueprinted
Ford GT40P heads
Custom FPS cam grind
Trick Flow intake
Holley 65MM Throttle Body
C&L 76MM Mass air meter with intake tube
Motorsport 24# injectors
Motorsport wiring harness with 89 GT computer
MSD 6AL with Blaster TFI coil
Custom made headers
Dynomax bullet mufflers
Aluminum 2 1 inch row radiator with electric fan
Transmission
C6 Ford
Red Eagle Clutches and Steels
B&M shift kit
Custom pan with skid plate and drain plug
B&M Pro stick shifter
Transfer Case
Atlas 3.8 to 1 with 1410 u-joint conversion
Axles
Front Ford high pinion Dana 60
-35-spline outer shafts
-35 spline rebroached Spicer lockouts
-new lockout chrome and plastic centers
ARB air locker with compressor
4:56 gears
High steer tie rod
new calipers and brakes
cold rolled steel diff cover
Rear Corporate 14 bolt
4:56 gears
Detroit locker
single piston disc brakes
cold rolled steel bar diff cover
Suspension
Front
-Bilstein Rockcrawler series 17" coilover shocks
-Hyercoil springs (dual rate) (185 top, 400 bottom)
3 link with a-frame (2 DOM bars with heims, 1 3 inch johnny joint)
detachable sway bar
Rear
-wishbone with 1 johnny joint
-trackbar
4" skyjacker softride YJ springs
Wheels/Tires
-Stazworks 16.5x10 Double beadlock
-SS Irok 39.5x13.50x16.5
Interior
-Vracing buckets
-4 point harnesses
-custom redone dash with all Autometer Carbon Fiber guages
-MTX speakers
-Premier Head unit
-remounted factory gas tank
Other
-109 inch wheel base
-Engine has 1700 miles on it
-Trans has 35 miles on it (used to have a stick)
-Drives very well on the street up to speeds of 80 MPH
-Like engine dynoed at 415 HP at 5500
-full new soft top with tinted windows
-also have swing out tire carrier that detaches
-Master power brakes dual diaphram booster
I built this jeep over the course of 3 years. I never had any intentions of selling it, but lately I have been thinking of building something else. The price range I am looking at is around 22,000.00 but I may take offers less. Email me at [email protected] for questions....I am sure I have left some stuff out LOL---Thanks!
1 - 4 of 4 Posts
