1 - 3 of 3 Posts
What design or manufacture are you using?
Are you happy with it?
Was the install easy or did you have to make any adjustments to get it to fit?
Who do you recommend?
Marlin
Jeepeater(anyone have the ph#)
Does Inchworm make this unit and if so same ? as above?
Thanx for all the help. I did do a search but I'd like to hear your thoughts on it today.
tom
Hey Man,,
I've got the AA adapter plate.. Works fine, only problem is you have to do some 'trimming' to get it to fit.. You have to grind down some of the tranny case to get a bolt into it..
If you buy the kit from Marlin he has specially made bolts to fit with the kit.. (ie no grinding required).
Grinding is easy though, so it's up to you..
Any more questions let me know..
1 - 3 of 3 Posts
