1 - 3 of 3 Posts
Are the tie rod holes in the knuckles tapered?
Understanding some interference with the sway bar components, is there an easy flip to put in a top side tie rod?
Also, with it being higher, are there any new wear concerns?
- Thank you
most tie rod ends are tapered, i use a bullet proof steering system tie rod, and it uses 3/4" bolts w/ heavy duty heim style joints
Did you have to do any custom ordering? Did you get the top mount kit or the stock replacement kit? Did you go with the trail duty or one of the others? How many miles do you have on it so far? Do you like it? Any problems?
1 - 3 of 3 Posts
