1 - 4 of 4 Posts
OK not Tuesday i know but sorta need some feed back i am pretty sure i can make this 1.5 inch gap a bit smaller by rotating the axle on the new perches, this in turn will help my shit pinion angle i currently find myself with. If i have to cut and rotate the housing so be it but i would like to see first what others have for clearance. and flame away if you like i can hang but a little helpful info inside a good dose of flame throwing is always appreciated:flipoff2:
thx CRS
Lower your perch height..... you cant get much but every bit counts....
billybob: ya i am with you but just wanted to bounce the idea off someone else first thx
Mr stubs; the perch is as low as i can go on the pass side its litteraly on the housing just as it sits ( hard to tell in the pic)thx tho
should have it cut and turned before midnight:flipoff2:
1 - 4 of 4 Posts
