Doing a Saginaw conversion, this truck is old had the steering box that the shaft goes all the way to the steering wheel, TS did not work, had an aftermarket ign switch no horn etc. I called the customer and suggested doing a GM tilt and solve a bunch of problems in one blow.
I went out to Justin's to fetch an S10 column, and he was out, so I trecked thru and found a good candidate, mid 80's Cherokee, still a GM part.
First step is to set it in the hole and fab up the upper mount, notice the rope to hold it in place.
