Running into an issue on my Ford, hoping this community can help.
I did a Sky Offroad Super Duty axle swap on my OBS. All new springs and shocks, whole 9 yards. Ever since finishing, my front passenger side is about an inch low at the door. Can’t figure out why.
What I have checked;
Wheels and tires: Everything matches and is even. Tires have identical pressure and are the same size. Same rims.
Suspension: New bilstien shocks, new springs should match
Reverse Shackle Kit: Double-checked all the suspension measurements, they match and are good. I followed Sky’s directions.
Axle components: Double checked I wasn’t missing a lift plate or something against other 4x4 2004 Super Duty F-350s (axle donor) and doesn’t seem like the passenger side is missing a lift plate. Shock mounts look identical so I doubt they are reversed.
Panhard Bar: New panhard bar looks adjusted fine, I had a good local shop do the alignment. Even if it was off I don’t see how it would cause passenger side to be lower.
Anything else I should be looking at? I am stumped.
