1 - 5 of 5 Posts
After reading all the posts I got from the search I did, I've decided to go for 36x12.5x15 SX and groove them to the "#3" tread type pictures in most polls (anyone else confused :rolleyes: ?)
Anyways, I'll be ordering the grooving iron for ~50$ with a nice selection of blades and go at it once I get the 5 tires.
One question pertains:
How much will the tire diameter increase after grooving?
I read in certain posts that this usually occurs, which is logical, since the carcass gets a wee bit "liberated" to expand somewhat, but does that apply to even smallish sizes as the 36"ers, or only for 40"+?
I'll be fitting them onto a Land Rover Discovery, and run some Challenges that do not allow for anything above 36.5" tall tires...
Thanks guys!
Discussion Starter · #2 ·
Also, Which blades do you recommend I use for the grooving? Should I buy spare heads, or only the blade generally breaks?
I went through 1.5 blades on all for of my 36" SX's. I used the 1/4" wide cuts. worked fine
not sure why the diameter would change at all. you're not cutting all the way through the tire. only the lug.:rolleyes: :rolleyes:
Mudlite...
Seeing that English is my 3rd language, and I was translating that quote from German (my 4th language), Its good enough I have one mistake...:D
I'll be going for the 1/4 inch, and I'll get several sizes as well, should I wish to be creative a bit.
IS there no way the diameter will increase? Will the SXs flex much better and perform much better?
1 - 5 of 5 Posts
