1 - 8 of 8 Posts
Alright I just took apart my 97 TJ with a 4.0 tonight and found out why I couldn't shift into any gear while the Jeep was running. I knew it was transmission related, so i just started tearing it all down. Here's what I found.
This is how the throw out bearing came out of the bell housing!
Clutch disc warped, cracked, and missing half of it's clamping material on one side.
Here's a completely destroyed Center Force II.
So...the question is...what should I replace it with? I've searched on ebay and located some clutches. I found a center force OEM replacement for 126 bucks shipped with everything. However, I heard bad things about Center force clutches (they seem to lose counter balance weights) and now im weary. I can get an OEM replacement from O'Reilly's for 130 with everything also.
Well I heard that an OEM clutch should be fine with only 190hp and 225ft/lbs of torque, a stock clutch should survive. I have some 1 tons in mind and a tire ranging from 39-44's in about a year or so.
I'm following the Carnage Clutch fix thread in the non hardcore section. He put in a clutch that I just took out.
yeah, LUK clutch has always been good to me in my junk. you don't need a racing centerforce for a DD/crawler jeep:flipoff2:
just buy the complete kit.....prolly around $200+. check the internet, i got mine for a good price at pep boys here in tucson.
make sure you get the flywheel re-surfaced. that only runs under $40 at your local parts house (they send it out).
replace the pilot bearing/bushing too while you are in there.
good to go
rockrnockr the FSM on TJ's specifically says not to resurface the flywheel. It says to scuff it with an emory cloth. I'll try Luk, I hope O'Reilly's here in OK can get one because my cousin works at one and gets me everything at his cost which equals super fawking cheap. :flipoff2:
It wont be DD for long! shit! :evil:
1 - 8 of 8 Posts
