1 - 8 of 8 Posts
So the bearings on my 35 in my 99 TJ went out and instead or rebuilding it (duh), I have decided on swapping in a rebuilt 44 from a 2000 TJ. What are my concerns if any. I will need to swap control arms and brakes onto the 44. Are they the same as the 35?
Any other issues, or is it a "bolt in" ?
Thanks
Bolt in....
Don't forget to make sure your gear ratios match. Sounds like a dumb point, but it's easy to overlook the obvious sometimes :flipoff2:
if you have a SYE hence cv shaft all should bolt up, but if you still have the stock shaft, you may have issues with the shaft hanging on at the tip of the slip yoke
mind if i ask what you managed to pick the D44 up for?
1 - 8 of 8 Posts
