1 - 6 of 6 Posts
I just got done building the jeep and i had the battery out to so so. I have a piggy back computer that is hooked into the ecu wires for map and ignition for my turbo kit but that is the only thing that is different from stock. I put battery back in and charged it on high charge for 10min and tried to start the jeep when i noticed the fuel pump is not whining which means it was not working. I wired it up manually to make it run and it would just turn over but never fire. I hooked up an OBD2 code reader and it says invalid and can not connect. sound like the ECU is messed up or something because all the fuses are perfect.
what ya think? i dont have a clue
1 - 6 of 6 Posts
