Ok.... Long story short, I started out with a new TJ 12 years ago, and after many rigs and lastly my stalled small buggy project, I've stepped into another TJ. This one is more/less a collection of parts. #1 is a complete roller minus drivetrain, dash apart. It was hit in the front and has unknown damage. Its a former wheeler, dents/damage all over. It's the parts whore. #2 is a clean tub that's been comp cut already, hood, grill etc.. Mix/Match of colors. Frame has already had lower link brackets cut off.
updated to reflect current direction:
Pics here:
https://nc4x4.com/forum/threads/new-jeep-project.69096/
Current Plan/Direction
2.2 Ecotec
R150 / AX15 input shaft, front thing
Toy T-case (w/ 4.7s)
Ruffstuff Toy 8" housing +6 long side w/ Elocker / Tacoma TRD 8" Rear (elocker)
2" Lowers w/ Ballistic Joints / 1.5" uppers w/ 7/8" Heims
14" ORIs
PSC 6 bolt JK mount steering box, more better...
CB PCS pump (acquired it)
35" KM2
New custom 2x4x.188 frame
Integrated 1" BL
Hi-Line rear floor/fenders
Lift = guessing 2"-3"
Original Plan/Direction
Jeep 2.5
G54 NOTE: The W56 Toy trans can NOT be used, only the bell swaps, with some input retainer work it might work.
Toy T-case
Toy axles Front/Rear
3/4"+ 7/8" heims/inserts
TG 8" full hydro steering setup
36 TSL Radials.
SO after many hours reading the TJ builds.... I'm thinking of.....
Minimal suspension lift (zero if it will work)
High Fender cut hood deal.
1" Body Mount Lift
Pull motor up some.
Push front out 4" slide rear back 2"
Links - yup, layout dono..
I'd like to keep the tub more/less intact. but otherwise what are some cool ideas you guys might have tucked away..
The one build with the front frame recurved looked interesting.
I'd like to dump the track bars, rear is np. front might need some planning for low lift.
So my questions are... (keeping in mind this is gonna be a medium size jeep)
What have you done on your TJ that you wish you hadn't?
What did you do right and are happy with.
What did you waste your time doing that didn't amount to shit ?
Input? Suggestions on my plans ?
It's not home yet but I snapped some pics when i was looking them.. I'll see if I can find the pics...
I've modified my overall direction a little as the project has evolved.
I wasn't happy with some aspects of the stock frame and felt it was limiting me.
I almost opted to sell off the project as I was finding so much I wasn't happy with.
That ultimately lead me to making my own frame.
After turning that corner everything started falling into place much better....
Follow along with my build...
Pics here:
2.2 Ecotec
14" ORIs
35" KM2
Integrated 1" BL
Jeep 2.5
Toy T-case
36 TSL Radials.
1" Body Mount Lift
Pull motor up some.
