1 - 8 of 8 Posts
Where do I find out what gear ratios my 97 and my 02 Jeeps have? In my other 4x4 it is in the door on a sticker. :confused:
Since this is a newbie question and I'm a newb I guess I'll answer. Crawl under the rear of the Jeep and there is a tag on the diff cover that will have it on there. If you have a stick and a D35 it will most likely be 3.07, if you have a D44 it will be 3.73. Don't know the auto ratios. This is assuming the gearing is still stock.
It has a I6 and an auto.
both do
I opend a dana 35 with the bild paper and ax tag = 3.75 but the damn thing had 3.55 .... and jp build up on there dana 44 was a open carrier but jeep says they did not put in a open in a 44 so the best way is to open it up and count the R & P... my $0.02 :flipoff2:
1 - 8 of 8 Posts
