I recently installed Waggy Dana 44's under my 00 TJ (discs front, drums rear), and as expected the factory MC could not flow enough fluid to the calipers/wheel cylinders. So after a lot of reasearch here on the PBB, I came up with using a 2001( 98-02 are the same) dodge 3500 Pickup MC, it bolts to the TJ booster without mods, seals great and the fittings for the brake lines are the same. The only thing I had to do was get a 1/4'' x1 1/4 '' fine thread bolt and grind down the head, this is the new pushrod, just adjust it until the MC hits the booster at the same time that the pushrod hits the piston in the MC. The only problem is the resiviour makes slight contact with the hood, I don't think it will cause any problems. As for the brakes, AWSOME stops better now than stock, and with far less pedal travel. If someone with a star wants to post the pics just shoot me a PM
TOTAL COST
MC= $ 31.00 (Junkyard)
Bolt=$ .19
TOTAL COST
Bolt=$ .19
