1 - 20 of 23 Posts
Originally posted by 97sahara:
<STRONG>I am having my new rearend narrowed for my TJ he is making it 62" WMS to WMS. I need to know if the TJ rears are centered or offset? Mine isn't here to check out? Thanks in advance</STRONG>
I seem to recall when my buddy did his 60 it was slightly off center.
I am running a SYE and RE Long arm kit with 6" springs. Can the axle be centered since I am using the SYE????
<STRONG>I am running a SYE and RE Long arm kit with 6" springs. Can the axle be centered since I am using the SYE????</STRONG>
well they are cutting the axil tubes to narrow it so u might as well have them do it right and cut the tubes to spec.
Save headaches i say
Originally posted by coachgeo3:
<STRONG>well they are cutting the axil tubes to narrow it so u might as well have them do it right and cut the tubes to spec.
Save headaches i say</STRONG>
I agree, what would the spec be, or how can I find out what the spec is? I am going by the tomorrow to talk to the shop about it,it is a race shop that specializes in rear ends(not a 4x4 shop)
I am having it narrowed to 62 WMS-WMS any idea on what each side would need to be?
<STRONG>I agree, what would the spec be, or how can I find out what the spec is? I am going by the tomorrow to talk to the shop about it,it is a race shop that specializes in rear ends(not a 4x4 shop)
I am having it narrowed to 62 WMS-WMS any idea on what each side would need to be?</STRONG>
i would look into the actual difference... and if you can run em the same , youll have one spare for both sides.... im pretty sure ill be building mine the same on both sides....
Originally posted by badassjeepguy:
<STRONG>
i would look into the actual difference... and if you can run em the same , youll have one spare for both sides.... im pretty sure ill be building mine the same on both sides....</STRONG>
Thanks I guess I need to find out wha tthe offset is from the factory and decide if I can run it centered. I like the idea of having one spare for both sides...
If anyone knows the offset please post it here. Thanks again
<STRONG>Thanks I guess I need to find out wha tthe offset is from the factory and decide if I can run it centered. I like the idea of having one spare for both sides...
If anyone knows the offset please post it here. Thanks again</STRONG>
It's offset. Pull the shafts and measure the difference - it should give you a pretty close idea.
Discussion Starter · #12 ·
I have access to a dana 35 empty housing if I took it to him with the 9" housing and told him to make 3/4" wider on each side he would know what to do. As stated before I am wanting to go to 62" WMS to WMs instead of 60.5".
to run the d shaft 1/4 inch off center would be fine imho.... if the one shaft is 29 and the other is 28.5, add the 2 together totaling 57.5 divided by 2 = 28.5 + half the increase in overall length which would be .75 = 29.25
[ 10-06-2001: Message edited by: badassjeepguy ]
Discussion Starter · #14 ·
<STRONG>to run the d shaft 1/4 inch off center would be fine imho.... if the one shaft is 29 and the other is 28.5, add the 2 together totaling 57.5 divided by 2 = 28.5 + half the increase in overall length which would be .75 = 29.25
[ 10-06-2001: Message edited by: badassjeepguy ]</STRONG>
Now you lost me, so are you saying run it centered???
<STRONG>Now you lost me, so are you saying run it centered???</STRONG>[/QUOTE
the difference was 1.5 inches not 1/2 inch ill go down and measure mine when i get some coffee in me
<IMG SRC="smilies/rolleyes.gif" border="0">
[ 10-06-2001: Message edited by: Trailhawg ]
You could always call Dynatrac, Currie or Sunray and see if they will give you the info on Monday. It sounds like you are building a 9". Depending on the third member the pinion yoke may be off center to begin with. SO watch out...
Originally posted by Trailhawg:
<STRONG>
[qb]Now you lost me, so are you saying run it centered???</STRONG>[/QUOTE
[ 10-06-2001: Message edited by: Trailhawg ][/QB]
oops sorry, guess i need some coffee too, wrote that up at 630am..... all previous statements about running centered, i retract...... sorry for the fawkup... if you ran centered it would be 3/4 inch.... i think thats gettin a little off....
<STRONG>oops sorry, guess i need some coffee too, wrote that up at 630am..... all previous statements about running centered, i retract...... sorry for the fawkup... if you ran centered it would be 3/4 inch.... i think thats gettin a little off....</STRONG>
While you're going through all the trouble - I'd sugest you set it up w/ the correct off-set.
Discussion Starter · #20 ·
Originally posted by AzJeep:
<STRONG>While you're going through all the trouble - I'd sugest you set it up w/ the correct off-set.</STRONG>
I took them a dana35 housing I had in the garage and gave it to them to take the correct measurements off of. I just told them to add 3/4" to each side. I hope this will be fine.....
1 - 20 of 23 Posts
