1 - 20 of 21 Posts
who makes the best ones? will I have to relocate my transfercase when using a SBC 700R4 combo with an adapter to my 231?
1. Make your own mounts
2. Yes a 700r4 is alot longer than your stock transmission. So that means a shorter rear and a longer front driveshaft.
3. To save some green, S-10's and Blazers had 231's mounted on 700r4's so you dont have to buy an adapter.
First: SBC + 700R4 is the SAME LENGHT than your 4.0 I6 + AX15 (or NV3550) which means you keep your actual drivelines.
Second: S-10's and Blazers never came with 231's. They came with NP233's which are different system. The inners are interchangeable but they are not 231's starting by the fact the 233 has a 5 bolt pattern and a 231 has a 6 bolt pattern.
:shaking:
These wont work on a TJ (maybe with a radius arm front suspension) but not a long arm 3/4 link or stock.
Those look like the ones that Advance Adapters sells as their "Offroad" mount for CJ/YJ :confused:
TJ to SBC mounts:
713090 SBC to TJ 4 cyl. https://eshop.advanceadapters.com/c...gine-28replacing-4-cyl-29-m-713090-713090.htm
713091 SBC to TJ 6 cyl. https://eshop.advanceadapters.com/c...gine-28replacing-6-cyl-29-m-713091-713091.htm
TJ to SBC mounts:
I'm running a RE Long Arm kit. o wonder if they would work?
Discussion Starter · #9 ·
I wonder why the SBC to 6cyl needs a cradle?
Discussion Starter · #11 ·
yeah but why?
Discussion Starter · #13 ·
You may be able to make them work. But I would be apprehensive. They may need to be modified. The TJ frame rails have a bit more of a roll to them to clear the front axle than a YJ or Cj.
I really want a set of those bad boys for a TJ!
there are other ways available but the cradle is by far the easiest and best. yah it sucks if you gotta drop the pan.. but being albe to use the stock gm mounts rawks.
i have the cradle setup in my yj...
:shaking:
First....your right on the first part.
Second.....your wrong on the second. 89-91 s-10 blazers DID come with a 231tcase. In fact....it's a called a 231C case.....and in fact....they also came on certain models with a 231C HD model that had the beefier shaft, gears, chain and 6 planetaries. Oh....and yes....it's a 5 bolt pattern. :shaking:
Third....the mounts you quoted from ebay...are MORE engine mounts. Give them a call, go to their website. I'm sure they can fix you up.
but I'm assuming that the linkage is different? slip yoke?
Discussion Starter · #20 ·
1 - 20 of 21 Posts
