TJM PRO LOCKERS NOW IN STOCK!!!
MSRP $1030.40
OUR PRICE $896.00
That's over a $130 savings! Most of these lockers are at least $100 less than the smaller ARB price. They feature a 2 year warranty like ARB, these are also a 4 pinion design with a great actuator system. TJM use's a piston type actuator that doesn't have a rotating sealing surface like the ARB. Both TJM and ARB are great lockers but we wanted to offer one more option! ARB compressors or an alternate 100 PSI air source can be used with these lockers. Enjoy!
MSRP $1030.40
OUR PRICE $896.00
Toughest locker on the market.
Experiencing life outdoors is best achieved behind the wheel of a 4WD.
But, why is that when you finally take your 4WD out of suburb onto what’s meant to be its home-turf that even the smallest obstacle becomes too challenging for your brand new, shiny 4WD? Well, it’s all about traction. Traction describes the relationship or grip that your tires have with the ground, and loss of traction is the 4WD’s number one enemy. Without traction, your prized 4WD will be about as useful as an exercise bike at a suburban gym.
Even though you've purchased a 4WD, its factory differential is designed for road use. To prevent premature wear on tires, it allows for easy cornering by delivering torque to the wheel experiencing the least resistance. This process works well on bitumen, but when you go off-road, your engine will send all its power to the wheel that comes off the ground, essentially, leaving you powerless.
The TJM Pro Locker solves this problem with the flick of a switch. An innovative air-operated differential locker, the Pro Locker effectively locks “traction-less” wheels and subsequently, the other wheels work harder to get you out. The Pro Locker allows you maximum traction and drive from all four wheels giving you the best possible chance of tackling formidable terrain. And all without getting your feet dirty. With the Pro Locker installed, you may never get stuck again.
A FEW ADVANTAGES OF USING THE TJM PRO LOCKER ARE:
1. Unique air operated piston style actuator aims to eliminate the risk of oil being pumped up the airline.
2. Hardened thrust washers and the size of the locking ring make Pro Locker extremely strong in operation.
3. Stronger materials and a thicker carrier compared to most standard differentials.
4. Larger pinion gears compared to most standard differential.
5. No carrier modification needed other than the drilling and tapping of a bulkhead fitting port.
6. Pre tensioned 10mm bolts hold hemisphere together.
7. Robust design equals less maintenance.
8. Reinforced rubber external hose extension is supplied as standard to minimize the risk of the airline being damaged by debris while driving.
9. Recessed colored L.E.D cabin switches show clearly when TJM Pro Locker is on or off.
SHOOT ME AN EMAIL OR CALL FOR AN ESTIMATE OR TO ORDER
[email protected]
866-349-6801 EXT.111
WATCH THE VIDEO BELOW FOR MORE INFO
TJM Pro Locker Air Locking Differential - YouTube
[email protected]
Current JUST DIFFERENTIALS In‐Stock TJM Pro Locker Application Guide
PART NUMBER‐ DESCRIPTION
168PL01 PRO LOCKER FRONT & REAR 12‐Bolt 30‐SPLINE 40, 60, 70, HJ75 SERIES Includes (2) Nachi E32010JA1LT Carrier Bearings – Ships with “Front & Rear” switch.
Crossover# RD142
Fits: Front Toyota Land Cruiser 9.5” 12‐Bolt 30spl Full Float *Does Not Fit Semi Float
Vehicles: Toyota LandCruiser HDJ80/81 (1990‐1997), LandCruiser HZJ80/81 (1990‐1997), LandCruiser FZJ80/81 (1993‐1997), LandCruiser BJ/HJ70 & BJ/HJ75 (1984‐1998), LandCruiser FJ/BJ40 & FJ/HJ45 (1969‐1983), LandCruiser FJ55(1968‐1979), LandCruiser FJ60/61 BJ60 HJ60/61(1981‐1987), Toyota LandCruiser FJ62 (1988‐1990)
168PL02 PRO LOCKER 100 SER IFS 8” IFS W/ 50mm BEARING 30‐Spline
Crossover# RD131
Fits: 98‐07 Toyota Landcruiser 100 Series 8” IFS
Vehicles: Toyota LandCruiser UZJ100 (1998‐2007), LandCruiser FZJ100(1998‐2007) LandCruiser HDJ100(1998‐2007), Lexus LX470 (1999‐2007), LandCruiser Amazon (1998‐2003) Toyota Cygnus (1998‐2007) LandCruiser 78 & 79 Rear (1998‐2007)
168PL03 PRO LOCKER TOYOTA 30‐SPLINE 8” 4Cyl Includes (2) Nachi E32010JA1LT Carrier Bearings –
Crossover# RD132
Fits: Toyota 8 ” Std & Rev, 4cyl
Vehicles: Hilux & Pickup Front (1979‐1985), Hilux & Pickup Rear (1979‐2010), 4Runner Front (1984‐1985), 4Runner Rear (1984‐2009), FJ Cruiser Rear W/O E‐Locker (2007‐2009), LandCruiser FJ80‐series, HZJ80, HDJ80 Front High Pinion Diff (1990‐1997), LandCruiser HZJ105, FZJ105, HDJ100, FZJ100, UZJ100 (1998+), LandCruiser II, 70 Prado, Bundera, LJ70, RJ70, (1986+), LandCruiser HZJ71, HZJ78, HZJ79.
168PL04 PRO LOCKER NISSAN H233B 9‐Bolt 33‐SPLINE GU/GQ /XTERRA/FRONTIER Includes (2) Nachi E32010JA1LT Carrier Bearings 50.00mm [1.969"] id
Crossover# RD135
Fits: Nissan H233B, 9‐Bolt , 33Spl
Vehicles: Nissan Xterra 6cyl Rear (2000‐2004), Frontier 6cyl Rear (1998‐2004), Navarra 6cyl Rear (1998‐2004), Pathfinder 6cyl Rear (1996‐2004), Patrol GQ Y60 (1987‐1998), Safari (1987‐1998), Ford Maverick Rear (1988‐1994), Patrol GU Y61 Rear (1998‐2009), Terrano II Rear (2003‐2006), Mistral Rear (2003‐2006), Ford Maverick Rear (2003‐2006).
168PL05 PRO LOCKER NISSAN GU/GQ FRONT 31‐SPLINE ALL Includes (2) Nachi E32010JA1LT Carrier Bearings 50.00mm [1.969"] id
Crossover# RD136
Fits: Nissan H233B, 9‐Bolt , 31Spl
Vehicles: Nissan Xterra 6cyl Rear (2000‐2001), Frontier 6cyl Rear (1998‐2004), Navarra 6cyl Rear(1998‐2004), Pathfinder 6cyl Rear (1986‐2004), Hardbody D21 6cyl Rear (1986‐1997), Patrol GQ Y60 Front (1987‐1998), Safari Front (1987‐1998), Ford Maverick Front (1988‐1994), Patrol GU Y61 Front (1998‐2009), Terrano II Rear (1997‐2002), Mistral Rear (1997‐2002).
168PL07 PRO LOCKER LAND ROVER 24 SPLINE 10‐BOLT BANJO 3.54
Crossover# RD128
Fits: Land Rover Banjo 10bolt 24 Spline 3.54 Ratio
Vehicles: Range Rover Front & Rear (1993‐98), Discovery Series 1 Front & Rear (1993‐98), Discovery Series 2 All (1999‐2004), Defender 110/130 & County (1993+), Defender 90 & County (1993+) Does Not Fit P38A
168PL12 PRO LOCKER FRONT RANGE ROVER T/C P38A/WOLF AXLE Includes (2) Timken Set 47 (LM102949‐LM102910) Carrier Bearing, Ships with front & rear switch
Crossover# RD138
Fits: Land Rover P38A T/C 24‐Spline 10Bolt with 205mm (8.07”) Flange Diameter
Vehicles: Range Rover Front (1998‐2006), Range Rover (1998‐2006), Discovery II –Non USA (2002+), Defender 90 & County Rear P38A (2002+), Defender 110/130/County P38A (2002+)
168PL11 PRO LOCKER JEEP DANA 44 3.73‐DN 30 Spline Axle
Crossover# RD117, DET187S‐16D, DS73613, PT2410, TT913A951 Does Not Include Bearings
Fits: Dana 44 All, D44 Front & Rear, STD & Rev, IFS & Disconnect, Rubicon Rear.
Vehicles: All with Dana 44 with 30 Spline Axles, 3.73 Down
168PL14 PRO LOCKER TOYOTA TACOMA & T‐100 No Carrier Bearings Included
Crossover# RD129, PT1650, TT913A541
Fits: Toyota 8.4” with Bridged Bearing Caps & 12 Bolt Ring Gear (USA Only!)
Vehicles: Toyota T‐100 (1993‐1998), Toyota Tacoma (1995‐1/2‐2011), Toyota Tundra (2000‐ 2006), Toyota Sequoia SUV (2001‐2007)
168PL15 PRO LOCKER DANA 44 JEEP JK WRANGLER 3.73DN 07+
Crossover# YZLD44‐3‐30‐JK, RD117
Fits: JK Jeep Dana 44 Front, Rear & Reverse Jeep Wrangler JK & *Rubicon Models No Carrier Bearings Included – *30 Spline Axles Needed For Rubicon Replacement
Vehicles: Jeep Wrangler JK Non‐Rubicon Rear (2007‐2011), *Jeep Wrangler JK Rubicon (2007‐2011)
168PLWHKIT PRO LOCKER WIRING HARNESS W/ 12V 60AMP RELAY & COMP SWITCH – One piece wiring TJM Pro Locker Direct Wire Kit for Front & Rear Pro Lockers with Compressor on/off switch.
167COMPLD COMPACT AIR COMPRESSOR FOR PRO LOCKER ACTIVATION Compact TJM Air Compressor for Pro Locker Air Locking Differentials, With Air Filter and Pressure Switch, does not include wiring kit (requires #168PLWHKIT)
87664 1/4 INCH HEAVY DUTY AIR LINE- BULK ( Sold Per 39”’ Cut)
87665 6 MM AIR LINE- BULK (Sold Per 39” Cut)
87666 PRO LOCKER ACTUATOR PL01F, PLO1R, PL02, PL04, PL05.
87668 PRO LOCKER ACTUATOR SUIT PL03F, PL03R, PL06
92031 TJM DIFF BULKHEAD FITTING
92032 BARBED MALE PUCH IN FITTING (H/Duty Line to 6mm Line)
92033 6MM HEAVY DUTY AIRLINE FITTING (Bulkhead to H/Duty Line)
92034 6MM AIR LINE FITTING (Connects to hose)
92035 TJM PRO LOCKER SOLENOID VALVE
92036 1/8 HEX NIPPLE
92037 ACTUATION SWITCH - FRONT
92038 ACTUATION SWITCH - REAR
