1 - 20 of 21 Posts
instead of taking the whole axle out, we took apart the CV and took the portal off the with "stub" in it. We drove the race out of the portal and now we have to press the pin out off the end of the cv to slide the seal off. I will post pic of that in a sec
Wow, the upper seal was leaking? Its usually the lower one in the "portal housing" picture that takes a dump.
See if you can get a crossreference of that seal in case of emergency. I'll dig up the seal # for the other one.
Cool tool that you made! I bought one from a dealer and have yet to try it out on anything!
Great pictures keep em coming!
To take my hub off, I used my press, and a fabbed horseshoe shaped fixture which allowed my to press the output shaft while supporting the hub. Kinda awkward since it's so large. Just another option... :D
Yep, I just rest my rotor on the press plates and press it off....oh, wait, you don't have disk brakes do you?:flipoff2:
Discussion Starter · #18 ·
well....... i am goin to put the pinion brake on the rear for sure (rs by the way), but i dont know with the front because of the motor oil pan. I might have to do as JR did,and put it up by the Atlas. We shall see.
1 - 20 of 21 Posts
