1 - 3 of 3 Posts
I have a 6.2/th400 with a toasted torque converter. I have a spare laying around but its from a 700r4 which is out of a 87 blazer also with a 6.2. its a 30 spline.
The TC off the 700 has 6 stamped around the outside and 15-g stamped on one of the balance tabs (balance weight?) the 400 TC has D4 stamped all around the outside. Are these TCs interchangeable? they look the same and both have a 6 bolt mount to the flexplate.
Edit: the th400 is an HD with the heavy inspection plate, not the tin one, if that helps.
1 - 3 of 3 Posts
