21 - 40 of 57 Posts
i dont have any experience with this subject except what is on this BB, but i was wondering if people take into account their pinion angle when shaving(as in take a little more off the cover too), or if everyone just cuts it straight across like at 0 degree pinion angle???
- Jake
- Jake
I cut the lip off of the bottom on mine at the angle that I needed(pinion is raised about 16º)...however, if you cut and plate the bottom and do so at a weird angle, you may not be able to get the carrier out. Make sure the opening is still large enough.
do you guys think that the bottom of the axle is durable after yall do that? seems like if you hit a rock it might fawk it up.
I think 1/2 inch plate will be durable enough. My toyota housing has been drug over a ton of rocks, and it holds up fine. I think it is about 3/16 thick.
Hello Govna
pretty sure 1/2" plate decently welded will work fine.:D
I know, old topic.
I just did mine this week, did not cut and plate, just sawzalled and ground. I left the bottommost bolt hole and trimmed the cover and diffguard to match. I got the 5/8" out of it (the difference between a stock D60 and a stock 14 bolt), also removed that damned lip.
How many shaved diffs are daily driven? and hows the bearing life?
I have about 25K miles on the shaved 14BFF in my Burb. No problems with housing distortion or bering failure and it's driven daily. I cut the bottom to the lowest bolt hole and didn't do any reinforcement.
Eric M.
I have done 2 now,both I just cut the lip off and ground them SMOOTH.The one I am building now(2nd one) I did think about cutting and plateing.But just not sure if it is worth it.
What about using one of those steal max cutting blades in a circular saw like halogrinder used to cut 1/2" plate for his cheap truck challenge over in the ford section.
I used a 7 1/4" wormdrive with a steel cutting carbide tipped blade.We use these at work.(sheetmetal/roofing).They work great.They are expensive though.I used it to cut the lip off with three cuts.Then used a 7" grinder to smooth it out.
I did mine with an abrasive wheel in my 7 1/4" circular saw and ground from there. I took 2 1/2" off and added a 1/2" plate back in. I had to shave the ring gear on a lathe with an angle grinder about 3/8" to clear the plate. I preheated, welded it with a high nickle rod, post heated, and wrapped it in insulation and let it cool. 6hr later it was still hot to the touch. It's not a daily driver but it seams to be holding up, no bearing failures yet:rolleyes: I have had some trouble getting the 1/2" plate to seal but mostly because I added two 1/4" bolts to the cover which doesn't leave much sealing surface.
I shaved my D60 the same way.
THE VOICE OF REASON
Here is my mess. 3/4" more ground clearnace than a stock dana 60
21 - 40 of 57 Posts
