Alright lets see your info on doing a shackle flip. If you have questions this is the place to ask them.
I have installed the ORD kit twice and it is a nice kit, but on my own rig, I'm with you. Cheap. Can't wait to ditch the blocks. Has anyone noticed if they move the axle forward in the fenderwell? I did one on a 67 and it did.pcorssmit said:I'm a cheap bastard. I cut a big ass hole in the bottom of the spring hanger, and stuck the shackle through it. I was gonna weld on some reinforcement, but haven't got around to in in the 6-7 since I did the flip job. Works for me. I used a 4" grinder because it was what I had, and later cleaned out the corners a bit with a torch in a buddy's driveway.
Pete
Yep, it sure does.Has anyone noticed if they move the axle forward in the fenderwell
TX_Mudder said:
I used the offset zero rate -- Mike
That's what I have. Totally bolt on.blazin said:Anyone have the Echobit one on thier rig?I am thinking about ordering these for the wife's Sub.Blazin![]()
The axle on my '83 was centered in the fender well after my flip. However, I have seen several trucks where it moved forward, including my brother's '70 K5 (not too bad, though), and my buddy's '77 Power Wagon (pretty bad). If you have angled blocks that are angled at the top (as opposed to the bottom), the effect will be worse. The big factor is how high the rear end of the spring is compared to the front, stock vs. flipped, if they are level stock, the effect will be more than if the rear end is higher stock.motorhead72k5 said:Has anyone noticed if they move the axle forward in the fenderwell? I did one on a 67 and it did.
I did a 4" ORD flip on a '70 K5 and then used a ORD zero rate to move the axle back 1.5"s to center it in the fenderwell. This pointed the pinon at the TC, perfect for a CV rear driveshaft.motorhead72k5 said:
