Lil'John said:
1972 472 = [email protected] and [email protected]
500 = [email protected] and [email protected]
1977 425 = [email protected] and [email protected]
Just pulling the numbers from one of my resources... that is what they had at the time(Chilton)Chief yelling alot said:
the 425 maks 320 FLBS at 2000 RPM
well its kida funny but also Chiltons 1979 Motors for 1980 had the same numbersLil'John said:
Out of curiousity, where are you getting your rating?
Ahh... I see what happened then. The number I quoted was the first year of the motor. I looked at the 79 ones and they had higher numbersChief yelling alot said:
also look hear
http://100megsfree4.com/cadillac/cad1970/cad79d.htm
that tourqu rating sounds like it should be for the 368
tsm1mt said:This a buddy of mine's tow-rig.
He's on his second 500 Caddy.
He also wore out the D60 rear and is now running a D70 and duals.
4-5mpg.. and with both rigs on the 30' trailer, doesn't pull up hills as fast as it used to with the single trailer (duh), and with the camper thrown in, wind sucks..
But he seems to be happy with the Cad motor, backed up by a TH400, into the (stock) divorced '205.
Chevy1972 472 = [email protected] and [email protected]
500 = [email protected]pm and [email protected]
Well, that same friend with the 500 runs Chevys in most of his other stuff.. including a 14:1 454... but for some reason he opted for the 500 for his tow rig.charlo said:You gotta respect a man who runs a caddy 500(or 513). But for the money cant you get more power from the chevy stuffs.
Charlo
For a better comparison to your numbers above, lets use the EFI 500:charlo said:You gotta respect a man who runs a caddy 500(or 513). But for the money cant you get more power from the chevy stuffs.
Chevy
89 454 = [email protected]????rpm and [email protected] or so rpm
87 350 = [email protected] and ???
I guess these numbers arent fair because of the FI but parts availablity and price make these fairly similar numbers look a bit better than the caddies numbers. The caddy takes the lead by far in the bragging rights category.
Charlo
I had the heads machined to pro-street specs with oversize valves
I had the stock intake ported & polished for better specs.
I had the quadrajet carb rebuilt & jetted
I put in a 300T cam
I added forged rods & Pistons
I added a Stage II rocker set
I added an HEI system
The block was bored .60 over to 507 CID
RPM's Torque Horsepower
3750 525.2 375.0
4000 503.1 383.2
4250 485.7 393.0
4500 470.1 402.8
4750 442.1 399.8
5000 418.8 398.7
5250 394.8 394.6
5500 363.9 383.1
5750 326.3 357.2
what about after 76Cliffhanger said:add 125hp to most readings you get of engines from 1972 through 1976
