1 - 12 of 12 Posts
For the guys running toy axles....Did you have to upgrade your master cylinder or can you get away with the stock sammy master cylinder and booster??:confused: I would like to have brakes that work after the axle swap.:D
With stock toy brakes disk/drum.... ive had no probs using stock master.... -yag
what yag said only if going to rear disk should you need to upgrade the M/C
HELL NO DUDE!!!! Get rid of that stock crap!!!! I have disk all the way around and I used a stock ......(looking both ways).....YJ master......(looking both ways). I can lock them rite up! It will bolt rite to the sammy booster with a little silly cone!
Since Im running 42" swampers I went to four runner vented four piston calipers all around with a master cylinder from an FJ80!
Brakes are scary good!
Oh yea, I put in a proportioning valve too!
TB
Chris,
Did you put in a proportioning valve?
I just added rear disk brakes and I can lock up the front easily with the stock MC but the rears don't lock up, I have to pump them a few times.
Discussion Starter · #10 ·
Thank you gentlemen(I use the term loosely):D One less thing to change the better.;)
1 - 12 of 12 Posts
