1 - 20 of 26 Posts
Does anyone here know who to see about replacing the Toy knuckles with Dana 44 type ends? I want a better turning radius, and this seems to be the way to get it. Trying to make up for the stretching of the wheel base, and it gets rid of the $100+ knuckle rebuild kits and the Birfs as well.
Kinda like Trail Toughs 'Big Suzana', but with a Toy chunk.
Thnx
That is what scwafish has. I am sure he will chime in here soon.....
Thnx
All-Pro Offroad
:flipoff2:
Yea SCWAFISH has one, it was made by ALLPRO, but they dont make it any longer. And want BIG $$$ to tool one up for me. :(
I have talked to 'Fish already 'bout it :(
I was hopeing that someone on the board could build it for me, Like ahhhhh........
Brent!!
Yea that the Ticket....... Brent!!!
:D :D :D :D :D :D
Holy Shit! Those All Pro D60/Toy hybrids are $4,400!! Without a 3rd member!! Makes Brents Big Suzana one hell of a good deal. His are 1/2 the price, probably 20% lighter, and they come with a a Sidekick third AND an ARB for around $2,100.
Yea its a good deal actually, but I have Toy axles, and want the size and strength of the Toy safts and Center chunk.
If I didn't already have the axles I would consider his the best bang for the buck.
I may have to Fab my own, I'll need to find a good machine shop first though, :rolleyes:
I need to call Brent and talk to him :D
My buddy has a toy/dana hybrid. Works well. He runs 38s, and no breakage on nasty shit. Did shear a couple spring pins!
My understanding is that you should probably hold off for a bit longer as the rumor mill is that there will be a high angle birfield coming out in the future. Keep an eye out on the Toyota section.
-Wayne
The new longs turn tighter than a 44 will.
There is no reason to do a hybrid..
That thread makes a good point about the angle not being really useful. I have stock Toyota birfs in mine, and my tires are only about a 1/2" away from the springs at full turn. I run a 37" MTR, and my rim offset is rather agressive with half the tire hanging outside the Samurai body.
-Wayne
You can always run either wheel spacers or 2" backspaced wheels... and then a twin-stick/ARB/hydro assist to make it possible to turn.
I'm about to order some 2" spacers from rockbuggysupply.com - they're $52 each. It'll be a bitch to turn, but I can always shift into 2LO to turn, and it'll let me fit the 38.5s sitting out back begging to be run. :grinpimp:
Discussion Starter · #13 ·
Good points listed by you all, and i had not known that a tighter radius Birf was being made. 38*, Kool.
I may rethink this then.
As far as the tires into the springs: wont hapen, there are no springs! :p
and the throw of the steering box: there is no steering box! :p
Yup, I am linking the suspension, and going full Hydro. Its the only way to solve a few little nagging problems I have, beside no $$$ :mad:
I wont be doing the build up till this fall when I take the rig aprt, till then its mostly stock axles, Fozzy locked in the rear, soon to be a lockright up front.
thanks for the info guys, now I have to save $$$ for the Longfeilds! :rolleyes:
the spacers will let your tires clear your springs easier, but you know that your scrub radius will be much greater, putting the tires way into the firewall at full lock......just a fyi. sorry to hijack thread
Shit, $52 each? Is that right? They better be gold plated. Why not just get some custom backspaced rims for about the same money?
-Wayne
I have a Hybrid
I built a hybrid D44 / Toyota axle. I could build another if the price were right!
I can e-Mail a photo if you would like to see it.
I built it using off the shelf axles that I can buy at the local spicer shop. It uses 760 / 297 u-joints available anywhere.
The initial price of building one may be a little higher, but it is well worth it. Oh and it is 62" from mounting surface to mounting surface.
Tim Taylor
Fabster
I have been collecting part and ideas and am getting together the tooling to build myself a toy-44 hybrid. It will use a toy V6 third, stock replacement Warn D44 shafts and CTM u-joints. Im planing on it being about 62" wide. If anyone is interested in having one built pm me and maybe we can work something out.
Randy
Randy
How do you deal with the difference in splines?
Do you machine the side gears, or re-spline the axle?
Fabster
The 44 shafts spline slide right into the toy third no modification needed.;)
Randy
1 - 20 of 26 Posts
